Castor corrected radius arms ... - Defender Source
Old October 18th, 2007, 09:47 AM
Retrofit's Avatar
Retrofit
Pat
1984 110 CrewCab 200Tdi
I will be placing an order for QT Castor Corrected front radius arms and I was wondering, going with a 3" lift should I get the 3 degrees or the 6 degrees of correction ?
Anybody run those ? Any alternatives for a 110 ?
Thanks.
Pat
Kirk Lazarus, Tropic Thunder
Old October 18th, 2007, 10:05 AM
Bowtracer's Avatar
Bowtracer
Peter Sherman
NAS 110
Thanks.
Pat
I would look at rte's stuff. caster correct the swivls & use the arms for driveline correction
Qt you may have driveline issues
Old October 18th, 2007, 05:02 PM
Hoosier's Avatar
Hoosier
Chris Hinkle
More than I need
Three degrees should be enough for 3" lift.
Old October 20th, 2007, 07:12 AM
Retrofit's Avatar
Retrofit
Pat
Well ...
It looks like it is going to be 3 degrees and I will give Rovertyme a call for sure. There work looks wickedly strong.
Always nice to have other inputs !
Pat
Old October 20th, 2007, 09:58 PM
Pat
Steve at Rovertym is a stellar guy too... I have his radius arms on my truck and I have a 4" lift on the soft top.
Radius arms or trailing arms sflash868 Defender Technical Discussions 12 May 28th, 2006 05:40 PM
Used D90 Radius Arms Northface Wanted 3 March 29th, 2005 08:42 PM
Looking for HD driveshafts, radius arms, and more chrisvonc Wanted 9 October 4th, 2004 05:05 PM
Radius and Trailing arms chrisvonc Defender Technical Discussions 18 June 9th, 2004 10:21 PM
WTB - Caster corrected radius arms Tawayama Wanted 4 February 12th, 2004 12:35 AM
