Carolina to Florida - Defender Source
Old March 5th, 2004, 01:49 AM
WCURoverD90's Avatar
WCURoverD90
Jason Habbal
1997 Defender 90 #1104
Carolina to Florida
Hello all,
I am taking my 97 Defender to Daytona for my spring break monday and was wondering if I should worry about the long drive...My defender is top notch and everything is running perfect on it. The thing that i am worried about besides gas mileage is the fact that 80 mph for 9 hours with as minimal stops as possible. I am wondering how it will hold up at the speed for that amount of time and back....Is there certain precautions i should take before setting out...The obvious thing i have heard is AAA (the first thing for a rover owner) I used to have AAA but never used it so i did not sign up with them again....I am leaving monday so rapid replys would be great....
Jason Habbal
97 D90 ST
Old March 5th, 2004, 03:19 AM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
Personally, I would change the fluids in my diffs (about 15 minutes), my Transfer case (add 10 minutes) my transmission (might be a bit longer for a 97 than my 94, but no more than 30 minutes), my oil/filter (15 minutes), check my tire pressues including the spare, quick belt check, remove top, pack cooler, get music selection organized and handy and you should be all set. If you have a lot of miles on your rig, I might jack up the front tires and check the wheel bearings by seeing if there is any wear (grabbing the top and bottom of the tire and push/pull and see if it feels loose). I might even drain the radiator fluid.
This might sound hard any "normal" trucks/cars, but on a D90, you should know how to do all this--it is ridiculously easy--I do this before any major trip anyways.
Realistically, you should be fine right from the words "top notch".
Old March 5th, 2004, 07:37 AM
Burke's Avatar
Burke
Burke Bell
'94 NAS D90 #158
Jason, we moved from Jacksonville, FL to Charlotte a couple of years ago and I had to make two trips up and down in my '94 soft top. You will be fine. 90s are not the choice highway vehicle for sure, but they will get you there. On my excursion I had 2 dogs, a cat, a full Rover, my hard top on, and it was 104 through GA (I have no AC)!!!! I survived, but I couldn't wait for that first cold beer! Have a good trip!
"I race cars, play tennis, and fondle women, BUT! I have weekends off, and I am my own boss." - Arthur
Old March 5th, 2004, 09:22 AM
12 hours to MAR nonstop 70 to 80 mph the all the way, if you keep up with your routine maintenance you will be fine.
Old March 5th, 2004, 09:31 AM
dmarchand's Avatar
dmarchand
David Marchand
'97 D90 SW Arles
I concur with Hippert. the mileage and long driving is no prblem if you do regular maintenance and the truck is running well. I did 24 hours of driving in a 48 hour weekend to get to MAR and back, mostly in the dead of night. My truck ran awesome, even on the way back covered in thick VA mud.
Old March 5th, 2004, 09:48 AM
WCURoverD90
Jason Habbal
Awesome,
Thanks for the info and the quick responces....Can't wait to get down there and show off the 90....
Jason Habbal
"tell them to phucough"
Land Rover-The Best 4x4xFar
Old March 5th, 2004, 09:58 AM
dmarchand's Avatar
dmarchand
David Marchand
'97 D90 SW Arles
Jason, are your traveling with other vehicles? No big deal if you aren't. I found it comical on long trips with other non '97 D90's, having to pull over for gas every 1.5-2 hours. When every other car, even the R380 D90's still has at least a quarter of a tank more than you.
On a long trip, you'll become the butt of all road stop jokes.
Or maybe that's just me....
Remember, their is no warning light for low gas either...
Old March 5th, 2004, 10:04 AM
chrisvonc's Avatar
chrisvonc
Chris von C
No Defender at this time
We did 2.5 days of 75mph highway driving cross the US and then back again in our D90. Just watch your temp, and I checked the oil every other gas stop, but had no issues other than wind noise.
Chris von C
[/size]
Old March 5th, 2004, 10:22 AM
Burke's Avatar
Burke
Burke Bell
'94 NAS D90 #158
Remember, their is no warning light for low gas either... [/B][/QUOTE]
Do we really have no warning light??? I have been thinking mine has been broken for 10 years now!
Old March 5th, 2004, 10:28 AM
dmarchand's Avatar
dmarchand
David Marchand
'97 D90 SW Arles
Pop the two screws off on that light panel and look behind the amber "Low Fuel" warning light. No connections to it.
Old March 5th, 2004, 10:36 AM
cbkearney's Avatar
cbkearney
Chris Kearney
Pile of Parts
I agree with Dave. He is the BUTT of all road stop jokes and for that matter road speed.
Chris Kearney
CB Kearney Fine Woodworking
250 Canal St
Lawrence, MA 01840
781.576.9171
Old March 5th, 2004, 10:44 AM
snuffer's Avatar
snuffer
Randy Black
'95 D 90 SW
Sounds like a good opportunity to burn out some of the carbon build up in the heads.
The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. -Thomas Jefferson
Old March 5th, 2004, 10:46 AM
dmarchand's Avatar
dmarchand
David Marchand
'97 D90 SW Arles
Thanks Kearney. I can count on you to keep it real.
You finally wake up after your long winter snooze or something? It's about time you got that thing back on the trail!
Old March 5th, 2004, 10:55 AM
cbkearney's Avatar
cbkearney
Chris Kearney
Pile of Parts
I have two weeks off starting the 15th. Where and when do you want to go? Or are you currently relagated to the Su Bar Ru (said in the snootiest Wellesley lock-jaw accent you can think.)
The reality is I am hung over, my kids are taking a test, and I am trying to get lost in cyber space. I think I have quadrupled my post count this morning.
Chris Kearney
250 Canal St
Lawrence, MA 01840
781.576.9171
Old March 5th, 2004, 11:00 AM
dmarchand's Avatar
dmarchand
David Marchand
'97 D90 SW Arles
Subaru for now. I'll have to borrow Jesse's truck if I want to do anything....
We should take a trip up north to the shop. Check things out.
Old March 5th, 2004, 11:12 AM
WCURoverD90
Jason Habbal
Well that sounds good....Can't wait for my gas bill for the month after this trip and back.....lol....Thanks guys,
Jason Habbal
Old March 5th, 2004, 11:14 AM
cbkearney's Avatar
cbkearney
Chris Kearney
Pile of Parts
I would be up for that. Have we successfully hijacked this thread? Boy is Chris V going to be pissed. Send me an e-mail and we can figure out a day. I sold the Vette so I am about to tear into my project.
Chris Kearney
250 Canal St
Lawrence, MA 01840
781.576.9171
Old March 5th, 2004, 11:15 AM
dmarchand's Avatar
dmarchand
David Marchand
'97 D90 SW Arles
That is sweet news. Check your email....I sent you a good link.
Old March 5th, 2004, 11:41 AM
sherpamike's Avatar
sherpamike
Mike Doligalski
'95 D90 ST
Jason,
I am headed to Ft Lauderdale this afternoon for my spring break. Maybe I'll see you down the road somewhere. Good Luck with the Drive!
Old March 5th, 2004, 11:56 AM
mattwhite
Matt White
94 D-90
Don't stop at Ft. Lauderdale, keep giong and spend the week in the keys
Florida Road MA jimmy salmon Trips, Trails and Events 53 December 23rd, 2005 10:57 PM
Florida Road MA. 7/16/05 ron Trips, Trails and Events 22 July 18th, 2005 06:18 PM
alone in the universe/ florida panhandle Rover- Girl Misc. Chit-Chat 50 April 1st, 2005 02:19 PM
2 Land Rover 110s for sale Florida SafariHP For Sale - Vehicles 0 October 20th, 2004 07:06 PM
Tallahassee, Florida... norros Trips, Trails and Events 0 May 5th, 2004 04:09 PM
