carb to fuel injection swap - Defender Source
Old April 18th, 2007, 11:22 PM
ember
ember bane
I have a complete fuel injection system with wiring harness and ecm that I was thinking about installing on my D-110. Just wondering if there is anything more than installing O2 sensors and connecting power. If anyone out there knows of more that I should consider (speed sensors, ect.???) please let me know.
Old April 19th, 2007, 07:00 AM
ECR's Avatar
ECR
East Coast Rover Co.
Just Defenders, nothing else.
Hopefully you have a 14CUX EFI system. These are pretty easy to install.
http://www.eastcoastrover.com/140.html
The items you have to install other than the easy stuff that is already in the harness:
Intake with all its sensors (TPS, fuel temp, coolant temp, fuel pressure reg, injectors), fuel pump that will pump EFI pressure, fuel return line, O2 sensors, speed sensor, a check engine light, mass air flow sensor, etc.
If you have AC you'll have to wire that in so the engine idle will be right with the compressor running and you'll need to make sure you have the EFI resistors in place for the 5 speed (if the EFI harness came from an automatic car).
It sounds a lot worse than it actually is.
Speed sensor and getting it installed is about the only thing that is a little tricky, but it isn't bad.
Good luck.
Email:
fuel
