Carb swap? - Defender Source
Old February 14th, 2014, 01:22 PM
Landyman1's Avatar
Landyman1
Landyman
1983 land rover 110 county
Carb swap?
Hello, I am looking to get a bit more oomph from the landy and maybe a few more mpg. One of these ways apparently is to swap out the stromberg/zenith carbs. I have heard people recommend edelbrock. I'm not sure which carb to get. Also, should I go manual choke or something else. I have an early 3.5l v8 so I don't have EFi nor do I think I'm ready to do such an operation. Advice please!
BTW: I did do a search on google and on the forum search tool
Old February 14th, 2014, 01:31 PM
Edelbrock Performer 500. Make sure to install an off road float kit.
http://www.edelbrock.com/automotive_...erformer.shtml
http://www.v8engines.com/faq-carb.htm
I would first make sure your cam and timing gear are in good shape as that is the main cause of low power.
Old February 14th, 2014, 01:36 PM
If you want better mileage, then I would do a bolt on TBI kit. More money, but it will give you the right fuelling all of the time right out of the box and always start and work...
Old February 14th, 2014, 03:20 PM
Paul K's Avatar
Paul K
Paul Kennington
'85 Ninety V8 SW
Stupid question (since I have the same problem) What is a TBI kit?
Current fleet: '85 Ninety 3.9 V8i Auto SW, two Discovery 1's (one for my Nephew, one for my Niece),'07 BMW 335Xi.
Old February 14th, 2014, 04:04 PM
robertf
Robert F
1995 Discovery
throttle body injection
It's made up from all the EFI parts off of a ~1987 to 1995 GM truck. Usually the kit omits spark control (just like the rover efi). It is a great option for engines that never had a factory EFI option.
The hardest part of installing these is running the fuel lines and mounting the pump, but once you've done that you might as well install the factory rover 14CUX EFI. It's not much more difficult or complex.
I've done several IH and AMC engines with home made kits. This page shows some of the more technical details behind the system
http://www.diy-efi.org/gmecm/ecm_info/1227747/
Old February 14th, 2014, 04:10 PM
Originally Posted by robertf View Post
..you might as well install the factory rover 14CUX EFI. It's not much more difficult or complex.
Except you end up with a 20 year old design using unreliable sensors and fuel mapping that is wrong and does not properly adjust.
A modern complete TBI kit will be easy to install and will self learn while using modern, easy to find sensors that are reliable. There are a dozen on the market. No farting around building stuff or becoming an expert.
If you were going to do a home made system, then I would suggest a Megasquirt kit out of one of the UK guys that do them specifically for the Rover V8. Not as simple, but cheaper a bit.
Old February 14th, 2014, 04:16 PM
robertf
Robert F
1995 Discovery
Modern TBI? I think we are talking about different kits. I meant howell or afi (or junkyard) you are probably talking about that ez-efi or whatever it is that includes a wideband for self tuning.
They ALL use 25+ year old designs for the sensors and actuators
EFI to carb conversion procedure wantone Defender Technical Discussions 5 May 3rd, 2013 12:39 PM
carb to fuel injection swap ember Defender Technical Discussions 1 April 19th, 2007 07:00 AM
Thinkin' about an engine swap! rustydefender Misc. Chit-Chat 11 June 17th, 2005 09:30 AM
Carb difference and door panels DIVERPRO Defender Technical Discussions 2 March 20th, 2005 05:31 PM
