Carb Replacement and Engine Questions - Defender Source
Old December 29th, 2013, 07:18 PM
irishwoody97's Avatar
irishwoody97
Woody
1983 One Ten County, Blue/White
I have finally started some minor investigation to begin work getting my One Ten up and running. My engine had to be replaced prior to import (from 200 TDi to its current 3.5L V8). I have found the engine serial, and discovered it is for a 1970-1983 RR, 9.35cr (#11D04680A). Are there any sights out there that can give me exact info on my particular engine (date of manufacture, any other specs, etc...)?
Also, the carb needs to be replaced. It currently has a Zenith 175CD. What do you recommend I replace it with? Mechanic in Germany recommended getting Holley, but I am open to recommendations on brand and specific model for this particular engine. Also, as a stupid newbie question, I assume that I need to order (2) carbs of whatever type I decide on; is this correct?
Thanks.
Woody
Old December 29th, 2013, 07:24 PM
ArmyRover's Avatar
ArmyRover
Bill Ski
83 110 "Frankenstein"
Edelbrock intake holley carb, is a good set up.
Unknown Author
716-898-8153
Old December 29th, 2013, 08:24 PM
I have one with an edlebrock manifold and edlebrock carb that I'm happy with.
Old December 30th, 2013, 09:01 AM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
Welcome Woody, this topic comes up from time to time and there are some guys on this board that have done some great jobs converting. I have owned a 3.5L with a Holley carb and I'm here to tell you it is a nice improvement. It is a bit tougher to find folks that can service the original carbs but they are out there. Maybe search for a local MG or Jaguar club if you need help in the meantime. But to your questions, search this forum and you should find the prior posts that mention what components others have used with pics of the finished product as well.
Regards
Clay
Old December 30th, 2013, 12:30 PM
mikeslandrover's Avatar
mikeslandrover
Mike Hammond
I used to swap to 1 3/4" SU carbs, much easier to set up and tune but probably very rare in the US nowadays, probably rare this side of the pond too now I come to think of it.
Common on 3.5 rover saloons.
Mike Hammond
ac, engine
4.0 Engine needs replacement... plz HELP! Cyborg Defender Technical Discussions 28 May 3rd, 2008 03:58 AM
Rebuilding a v8 engine - how to fix liner problems robisonservice Defender Technical Discussions 10 August 19th, 2006 10:18 PM
Transmission replacement questions cgalpin Defender Technical Discussions 1 August 1st, 2006 12:16 AM
Should LR Address these Engine Fires Ragland Defender Technical Discussions 49 December 13th, 2005 01:21 PM
