carb bang - Defender Source
Old October 22nd, 2008, 10:15 AM
lmfi04
Luai Jamal
1993
carb bang
Hello ... I own a 93 110 pick up with a 3.5 twin carb v8 .. a few weeks ago i noticed the truck was vibrating and shaking more than normal and when i reach speeds up to 100-110 kph or when the engine is under pressure as in dune bashing i would hear a very loud bang and the engine dies then restarts in a couple of seconds .. so I removed the hood and drove the car hard and found that it was coming from the right carb ... I've never delt with twin SU s before so any Ideas ....
Old October 25th, 2008, 02:39 PM
mikeslandrover's Avatar
mikeslandrover
Mike Hammond
Check the float level, it might e flooding.
Mike Hammond
Old October 26th, 2008, 08:18 PM
Gren_T's Avatar
Gren_T
Gren Thomas
1985 90 300tdi auto
also check that the pistons holding the needle are free to move with equal resistance, while you are at it check the oil in the dash pots on the top of the carbs.
would be a good idea to strip the piston housing off the carbs and clean all parts with carb cleaner to get rid of any gum, refill dash pots with engine oil.
also clean pipes from rocker breathers to carbs and clean/replace flame traps.
another a major cause of carb back fires is poor ignition timing.
have fun
regards
Gren
Old October 26th, 2008, 08:26 PM
jimmy salmon's Avatar
jimmy salmon
jimmy salmon
94 D90 AA Yellow
put a few drops of 3 in 1 oil in the carb, somehow it always seems to be the right carbs on su's that sticks
3rd low and BOOT IT
Old October 27th, 2008, 10:42 AM
Gren_T's Avatar
Gren_T
Gren Thomas
1985 90 300tdi auto
Hi jimmy i noticed that.. my v8's rh hand carb used to play up even after i refurbed it..bloody queer!
Gren
Old October 27th, 2008, 09:15 PM
kellymoe's Avatar
kellymoe
kevin
defender 130
When that happened to my truck I put a few drops of #1404 Edelbrock. Cleared it right up
Old October 28th, 2008, 03:32 AM
mikeslandrover
Mike Hammond
Does that come in a handy dispenser?
Mike Hammond
Help With Holley Carb Tuning nimbusnic Defender Technical Discussions 12 January 28th, 2009 10:23 AM
Best/worst bang for Buck! thewap Misc. Chit-Chat 10 November 9th, 2006 10:56 PM
Carb difference and door panels DIVERPRO Defender Technical Discussions 2 March 20th, 2005 05:31 PM
a one carb manifold for the V8 engine DIVERPRO Defender Technical Discussions 3 March 9th, 2005 11:46 AM
twin SU carb and intake off of a 3.5 draaronr For Sale - Parts 1 January 1st, 2005 11:28 PM
