Car (Truck) Dolly - Defender Source
Old January 5th, 2013, 06:04 PM
cjbenway's Avatar
cjbenway
Chris Benway
1984 LR 90 ( Hedrick Rover )
Car (Truck) Dolly
Anybody use one?
Do you just put everything in nuetral?
...or is it better to use a full trailer?
I need something to get it to the garage for the maintenance I cant do.
...which is most of it.
Old January 5th, 2013, 06:21 PM
Macker's Avatar
Macker
Mack Crouch
1988 110 LS 5.3
A full trailer is better in my opinion, but if your intention is soley to take it to the shop a relatively short distance away, a dolley will save you some money and space. It's a pain if you have to backup though...
Old January 5th, 2013, 07:39 PM
Baldewin's Avatar
Baldewin
Chris Baldewin
Bastard 90
I believe you also need to remove the rear drive shaft as well if you are using a dolly.
Old January 5th, 2013, 07:48 PM
Macker's Avatar
Macker
Mack Crouch
1988 110 LS 5.3
You could dolley it with the driveshaft still on but the transfer case in neutral. I have heard of people towing across country like this with no issues. I forgot that when I had mine on a tow dolley, I had the driveshaft removed for unrelated reasons.
Old January 5th, 2013, 08:14 PM
Pull the rear shaft it's 4 bolts and 10 minutes
Old January 8th, 2013, 09:34 AM
cjbenway's Avatar
cjbenway
Chris Benway
Thanks guys,
Im pretty sure since my 84 ROW 90 has a center differential I dont need to pull the rear shaft.
I just have to make sure the center diff is in nuetral.
Just looking for confirmation.
Old January 8th, 2013, 10:31 AM
LRover's Avatar
LRover
J. Michael McCaig
You can flat tow with the transfercase in neutral but you will burn up the center diff if you don't have all four wheels rolling. Best to pull the driveshaft when using a dolly.
Old January 8th, 2013, 11:26 AM
cjbenway's Avatar
cjbenway
Chris Benway
Thanks, I think Ill scrap the Dolly idea.
Old January 8th, 2013, 11:40 AM
Originally Posted by cjbenway View Post
Thanks guys,
they all have center differentials.
Old January 8th, 2013, 04:28 PM
cjbenway's Avatar
cjbenway
Chris Benway
Ya, I know they all have center diffs, just stating the obvious I guess.
....Except wasn't there a series model that Land Rover experimented with 2 wheel drive?
I would just be using the Dolly 2-4 times a year averaging 1 to 4 hr. trips.
I could use a full car trailer for other stuff though, so I think that's the way to go.
1997 Range Rover P38 4.0 SE $6k KKilo23 For Sale - Vehicles 3 February 19th, 2006 02:47 PM
Mikes truck on the trail????? scoloco Trips, Trails and Events 20 October 27th, 2005 10:21 PM
Car hauler question PT94D90 Defender Technical Discussions 6 May 19th, 2005 08:49 PM
D90 Car Cover with Storage Bag Erik For Sale - Parts 3 September 21st, 2004 12:51 PM
