Car hauler question - Defender Source
Old May 14th, 2005, 05:40 PM
PT94D90's Avatar
PT94D90
Phil
Currently Defenderless
Car hauler question
Just bought a car hauler for the 90 and my question is, what is the best way to secure the truck to the trailer? This trailer has 4 d-rings on the deck, so I'm assuming I want to use heavy-duty ratchet straps but I'm not sure what to anchor to on the truck. I have a Rockware bumper with 2 shackle recovery points and a receiver-mounted shackle recovery point in the rear. Are these acceptable to ratchet to or should I be using other parts of the truck?
Old May 14th, 2005, 09:31 PM
Whatever you do make sure you anchor the axles to the trailor too.
Old May 15th, 2005, 12:10 AM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
Get a set of JATE rings, that's what the british military does. Just make sure to tighten it down enough to compress the suspension, which will prevent it from bouncing around.
-Hans
My oil line fix
My 100k stopped odometer fix
Old May 15th, 2005, 09:58 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
Phil, the bumper in the back is fine. What do you have up front? I have trailered stuff all over and never had a problem.
Legend in My Own Mind.
Old May 15th, 2005, 11:49 AM
DaveHuny's Avatar
DaveHuny
Van Der Waal
none
1. Secure the axles. This alone will prevent the vehicle from hopping around on the trailer. If your 90's suspension can handle driving on any road, it can handle the slight bouncing from the springs while on a trailer.
2. If you feel like it, you can secure any other part, ie, frame, bumper. However, a 90 SW with 100 lb tire on a roof rack doesn't wiggle around enough to justify this.
3. Don't just secure from the frame. What happens is the whole weight of the vehicle stretches each tie down strap with each bounce, and it can slide the truck around a little, especially if it rains during your trip.
4. The only time vehicle movers crank the suspension down is when they are transporting a car with a unibody chassis with independent suspension which could bottom out on the trailer, or they don't want 30,000 lbs of cars all bouncing in sync with each other and rolling the trailer or something.
Hope that helps.
Old May 15th, 2005, 11:56 AM
PT94D90's Avatar
PT94D90
Phil
Thanks for the replies. Randy, I have the RW front bumper w/2 recovery points.
I did some research on the net and apparently this is a bit more technical than I imagined. As Ron and Dave said, it's imperative that you use the axles to tie down. 2" straps, rated 1 1/2 times the weight of the vehicle. Two around the front axle pulling forward, 2 around the rear pulling rearwards. It's also important that the angle of the straps from the axle to the tie-down point on the deck is between 25 -35 degrees. Here's a good link of anyone is interested. This place also has some really nice tie-downs.
http://www.trailer-parts-forless.com..._down_tips.htm
Old May 19th, 2005, 08:49 PM
BarryO
Barry O'Mahony
97 D-90 SW LE
I wouldn't trust my D-90 to nylon straps. I've used Transport grade chain and chain binders when trailering: one chain in front, one in back. Same as I use to trailer a tractor or any other piece of heavy equipment.
Stock '90's have two lashing rings in the back, and two in the front. I run the back chain through the two in the back, and tighten down with the chain binder. The two in the front got taken off when I installed the ARB bumper, but I use the two recovery points on the bumper instead (another option is those JATE rings that are designed to be installed simultaneously with the bumper).
With steel chains, I don't worry about stretching or chafing. This chain is hardened and can't even be cut with bolt cutters.
auto repair shop equipment and car hauler for sale mountainviewrover For Sale - Parts 10 September 17th, 2009 10:36 PM
2007 Carson Car Hauler pushngo For Sale - Parts 8 March 20th, 2009 03:21 PM
Car Cover Question floyd650 Defender Technical Discussions 4 February 19th, 2008 03:10 PM
Baby Car Seat QUESTION Flagg Misc. Chit-Chat 5 August 4th, 2007 06:39 PM
16' Car Hauler PT94D90 For Sale - Vehicles 3 June 11th, 2006 02:33 PM
» Defender Registry
LELOTRK
jefhuf
EXP-D1
MECA58
Add your Defender
