Capacitor on Alternator - Defender Source
Old September 24th, 2014, 08:52 PM
ScottS's Avatar
ScottS
Scott Shelley
Ok. I have 1994 Defender 90. I am replacing my Alternator and the new one came with the wire from the capacitor routed to the terminal that goes to the battery. The old alternator had the capacitor wire routed to the terminal that has the push on connector. Can someone look and see where it is supposed to go? Thanks
Old September 25th, 2014, 01:47 AM
ScottS's Avatar
ScottS
Scott Shelley
Bump....nobody?
Old September 25th, 2014, 07:24 AM
Probably a radio noise suppressor. Post a picture.
Old September 25th, 2014, 08:14 AM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Leave it off and see if there are any ill effects.
Those things are a nuisance when they fail and short out.
If you don't need it, you will be better off putting it in the round file that gets emptied in the trash.
RDavisinVA
Old September 25th, 2014, 09:55 AM
ScottS's Avatar
ScottS
Scott Shelley
Old September 25th, 2014, 10:02 AM
the rover shop
shayne young
As mentioned before.. That is just a noise suppressor.. Stops/reduces that annoying buzzing sound through your radio that increases decreases with engine revs.. It just needs to be on any output power source from the battery, I have seen them placed on either..
Old September 25th, 2014, 10:13 AM
ScottS's Avatar
ScottS
Scott Shelley
Thanks for the help!
Ominous Alternator noise! Eric Siepmann Defender Technical Discussions 14 May 16th, 2005 05:34 PM
Alternator Abrooks Defender Technical Discussions 8 March 15th, 2005 10:59 AM
Mean Green Alternator install tmore Defender Technical Discussions 4 May 11th, 2004 02:45 PM
Bosch Alternator tmore Defender Technical Discussions 0 April 9th, 2004 11:46 AM
Alternator/Battery problem - Repost Eric_S Defender Technical Discussions 1 January 19th, 2004 09:57 AM
