Cap / Rotor - Defender Source
Old May 23rd, 2005, 10:11 AM
tmore
Tom More
1995 D90
Cap / Rotor
Probably a stupid question but I can't get my rotor ( distributor) off.. shouldn't it slide straight off, or am I missing something?
Old May 23rd, 2005, 10:36 AM
DaveHuny's Avatar
DaveHuny
Van Der Waal
none
Do you mean the distributor, or just the cap, or just the rotor? The cap has 2 clips that hold it on. The rotor just pulls straight out (up) from the base, although I've had them be stuck on there pretty hard.
Old May 23rd, 2005, 10:42 AM
Make sure to mark it before you pull it out!
Old May 23rd, 2005, 10:49 AM
DaveHuny's Avatar
DaveHuny
Van Der Waal
none
Doesn't it only go on one way?
Old May 23rd, 2005, 10:50 AM
I ment the distributer as a unit. But the cap can go on 180 out of wack also, I'm not sure on the rotor.
Old May 23rd, 2005, 11:17 AM
tmore
Tom More
1995 D90
I am only having a problem with the rotor.. I can't get it to pull off.
D-90 cap and rotor roverboy For Sale - Parts 4 March 20th, 2007 03:46 PM
Wobbly distributor cap? and an update on my starter problem MiniGuy Defender Technical Discussions 6 January 10th, 2006 10:13 AM
? Quick ? About Dissy Cap RoverChic Defender Technical Discussions 6 February 4th, 2005 07:13 PM
Need replacement locking gas cap vnrover Defender Technical Discussions 17 April 10th, 2004 04:29 PM
radiator cap 97 jorge Defender Technical Discussions 2 November 7th, 2003 09:12 AM
» Defender Registry
G4
CamelTM
Outland
Outland
Add your Defender
