Can't Wait Until I get My Hands On - Defender Source
Old February 13th, 2006, 09:35 AM
The Wizard's Avatar
The Wizard
Douglas Wozny
1994/ Defender 90 #500
The engineer who designed the headlight for the '94 D-90. Had to change the left headlight this weekend. unscrewed 13 screws before I could plug the light. Another four screws had to be unscrewed to release the bulb from it frame. Compare this with my '74 CJ5 where I think I only need to uscrew 4 screws. What do you expect from a country that drives on the wrong side of the road.
The Wizard
To paraphase "Oddball" (Donald Sutlerland, "Kelly's Heros", 1970) "I only drive 'em, I don't know how to fix them."
1994 Defender 90 No. 500
Old February 13th, 2006, 09:48 AM
JackW's Avatar
JackW
Jack Walter
1966 109 SW Diesel
My 356 Porsche - 1 screw to remove headlight assembly - spring clip holds headlight in bucket
My long gone 1984 190D Mercedes - slide up access door behind headlight - undo spring clip (no tools) - push headlight out front of car - replace
A friend of mine's Mitsubishi - disassemble half the front end of the car - many, many fasteners
Old February 13th, 2006, 10:14 AM
JBurt's Avatar
JBurt
Jesse McCoy
'89 RRC SWB (needs work)
Yeah, do a VW new beetle...
Owner's manual reads; "Take vehicle to dealer", no shit, take it to the dealer! You have to remove the airbox, and that's nothing compared to the passenger's side, I'm pretty sure you have to remove the alternator.
"It's not a Jeep"
Old February 13th, 2006, 10:46 AM
Chris V
Guest
Posts: n/a
See now if you were smart while you were in there trying to replace the head lamp you would have replaced the wiring and added an upgraded headlamp wiring harness with a relay in it . This way when you do the inevitable H4- Ecode up grade with higher wattage bulbs you wont burn out the headlamp switch
Old February 13th, 2006, 05:28 PM
d901560's Avatar
d901560
Brian B
94 ST
I used to have a New Beetle TDI when I was commuting and I remember reading that. One of my neighbors had one too and he showed me the trick to changing out the headlights. As I recall, there's a latch behind the headlight that once released will allow you to rotate the entire headlight assembly and pull it forward out of the car. Replace the bulb and push it back in. It can be done in few minutes with out tools. LR dealerships aren't the only rip off.
Old February 13th, 2006, 06:19 PM
WOW that sucks, I can change my bulbs by opening the hood and grabbing the bulb from behind!
Old February 13th, 2006, 09:03 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
same
I can't wait for the weather to warm up! themaxx Misc. Chit-Chat 15 February 28th, 2008 09:28 PM
Average Wait for Rockware Bumper? cellulararrest Defender Technical Discussions 18 January 30th, 2008 08:22 PM
for whoever wants a good laugh at the hands of W jperakis Misc. Chit-Chat 10 October 19th, 2005 06:20 AM
ARB Lockers.... Can't Wait Any Longer mhansen Misc. Chit-Chat 8 March 21st, 2005 12:44 PM
Time on your hands? scrover Misc. Chit-Chat 3 November 3rd, 2004 08:25 PM
