can't start, no fuel supply - Defender Source
Old January 24th, 2010, 11:24 AM
ditskovich's Avatar
ditskovich
dmitry
Range Rover Sport 2013
So I put the car together, finally. And now it is time to start it. Sparks are there, but no fuel supply. Should I reset something, like Inertia switch? Any ideas, why it is not getting fuel?
Old January 24th, 2010, 11:37 AM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
Let's start easy--when you turn the ignition on, can you hear the fuel pump running? If no, then check the silver bosch relays by the passenger kick panel--one is for the fuel pump, one is for the ignition system. If you can hear your fuel pump, I would start by seeing if you are getting fuel at your fuel rail--if not, then probably your fuel filter. If you are, then probably your injectors. Good place to start.
Old January 24th, 2010, 07:00 PM
Man Dmitry you should have done this back when you had none of the body put on. It would be much easier to troubleshoot without it all in the way.
I don't have any better suggestions than these guys, but if you can't hear the fuel pump and you are sure the silver relays are good (or try new ones) then your probably going to need to drop the fuel tank and make sure you are getting voltage there, and if you are then the pump is bad (otherwise figure out why no voltage).
fuel, start
YANST (Yet Another No Start Thread) - fuel pump circuit issues cgalpin Defender Technical Discussions 25 August 2nd, 2009 11:23 PM
