Can't Shift Into Low Range - Defender Source
Old May 21st, 2010, 05:42 PM
rr1
john
1997 D-90
Hoping you guys can help: I have a '97 D-90 and the transfer case shifter seems to be frozen. When I try to shift it into low range (while in neutral, and at < 5 mph or stopped) it won't budge... It has engaged in the past, but now seems frozen.
I usually try to shift it into low every few months to keep it working, but I may have waited too long this time (yeah, I know, I should wheel it more often...). I have tried forcing it, but I'm afraid something's going to snap.... Help a brother out... Thx,
Old May 21st, 2010, 05:53 PM
Check the linkage... If you force it, you could crack or bend the L bracket in the linkage.
Old May 21st, 2010, 06:03 PM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
There is a lockout solenoid on the transfer case that will prevent you from going to lo if it fails, easy and cheap fix. Happened to Marchand on the first day of our Colorado trip a few years ago.
Old May 21st, 2010, 06:38 PM
GYM's Avatar
GYM
Gary
97 SW
Really? I know to keep a spare brake light switch in each of the '97s in the event of a locked out A/T shifter, but am not familiar with a lockout solenoid on the T-Case.
Maybe David can chime in with more info?
Old May 23rd, 2010, 09:58 AM
texmoto
david summers
99 Discovery II
The safety lock out solenoid is located on the top of the transfer case. It has a metal pin that retracts when the transmission is placed in neutral. When the solenoid fails, the pin will not retract, keeping one from shifting from high to low (or vise versa) whenever the POS decides to fail. Its held on by a cover with 4 small bolts (10mm ?). Remove the solenoid and discard it or cut off the pin and replace it.
Old May 27th, 2010, 12:27 PM
GYM's Avatar
GYM
Gary
97 SW
Thank you, David (texmoto).
Old January 6th, 2012, 11:32 PM
geoellis's Avatar
geoellis
George
1995 D90 #2904 - BB
I'm having this problem with my '95. The shifter just won't budge at all. It's frozen in High and unlocked, thankfully. Any clues as to how to free up the linkage?
1997 P38 4.6
1998 P38 4.0
2011 LR4
Famous Land Rover owners Lindy Misc. Chit-Chat 4 June 15th, 2009 08:49 PM
FS 2001 Range Rover 4.6 HSE **MINT** Low Miles! Stmpede For Sale - Vehicles 16 April 9th, 2009 03:58 AM
1999 Range Rover 4.6 HSE - Low Miles mlepisto For Sale - Vehicles 0 February 12th, 2006 10:45 PM
