Cant remove the cooler lines!! - Defender Source
Old April 6th, 2013, 04:16 PM
huibae's Avatar
huibae
Harold Lee
Jon Snow Badge 1122
Need help.
Working on changing out the cooler lines on my 97 Defender LE.
Radiator lines came out easy. I cant remove the ones below.
Tried PB blaster.....wont budge.
Any suggestions?
H
Old April 6th, 2013, 06:27 PM
RRCbass's Avatar
RRCbass
Rob Bass
1990 Range Rover Classic
I'm not sure of your setup but I was able to take off the oil cooler completely by removing the oil filter and then a nut inside the assembly. If you can get it off then you should be able to work the lines off at the work bench. Hopefully you have the exterior oil cooler like I had on my 3.9....
Old April 6th, 2013, 08:21 PM
ipgregory's Avatar
ipgregory
Ian Gregory
'97 D90 ST #1008
He's talking about a 97 so the cooler lines go into the front cover, not an adaptor above the filter. He will have to do them in the truck unless he wants to pull the front cover.
Old April 6th, 2013, 08:26 PM
RRCbass's Avatar
RRCbass
Rob Bass
Yea that's what I figured. I'm not sure which engines are in which trucks during which years! Those are defiantly a tougher fix. I ended up scrapping my lines all together. I know there's been much discussion about that in other threads but since my 87 had no oil cooler whatsoever, I'm sure it will be fine.
Old April 7th, 2013, 12:31 AM
huibae's Avatar
huibae
Harold Lee
Jon Snow Badge 1122
Figured it out.
I cut the metal part of the original line with a pipe cutter.
Then I was able to get a socket wrench around the bolt.
What a headache! The new SS lines from Eric are in and look great!
Old April 7th, 2013, 08:56 AM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
That's what I'll be doing. I don't think they are necessary for what I do and where I drive either. No plans to trek Bahrain in the future.
Clay
Transmission cooler lines?!? tron Defender Technical Discussions 2 September 29th, 2005 08:39 AM
oil cooler lines CHRIS C Defender Technical Discussions 39 December 21st, 2004 11:30 PM
Oil cooler lines revisited rover4x4 Defender Technical Discussions 5 July 9th, 2004 08:40 AM
Stainless Oil cooler lines??? Neo Defender Technical Discussions 3 February 3rd, 2004 08:04 PM
