Can't get window crank off - Defender Source
Old December 14th, 2015, 09:17 PM
quick968's Avatar
quick968
Mikey
97 Defender 90
So I'm looking at the workshop manual illustration on removing the window crank, and they show popping off a center plug to access the screw. Problem is my 97' SW window crank doesn't have that center plug. It's just one piece. Even if I push in on the door casing panel I can't see any snap ring or circlip or any way to get the silly window crank off. Any help?
Cheers
Mikey
Old December 14th, 2015, 09:28 PM
Roverdoc's Avatar
Roverdoc
Dan Kemper
1997 D90 SW #278
Buy a window crank remover tool of amazon, slide in and pop of the circlip. super easy with a tool. Push the door card in alittle and you will be able to see the clip and which way to use the tool. did this multiple times recently on my 97
------ Follow up post added December 14th, 2015 10:31 PM ------
http://www.amazon.com/Lisle-35440-Bo...+crank+remover
It is the black tool, may be a good time to get some panel poppers as well.
window
Where can I get this window seal? Maximal Defender Technical Discussions 1 February 13th, 2013 11:35 PM
How do these get into the USA and get sold? Grover Misc. Chit-Chat 33 April 23rd, 2012 01:15 PM
Aftermarket window crank options? jaygoss Defender Technical Discussions 4 September 6th, 2011 01:35 PM
Still possible to get all the window seals for the D90 fiberglass top? Neil McCauley Defender Technical Discussions 2 February 3rd, 2011 02:35 PM
'97 SW window handle crank J4hand Defender Technical Discussions 2 August 8th, 2004 08:51 PM
