Can't get Pitman arm off - Defender Source
Old April 6th, 2016, 01:16 PM
sflash868's Avatar
sflash868
Stephan Laputka
1995 D-90 SW
OK, i've tried and couldn't do it. Took it to two separate shops and they can't it off either. Is there a trick to this that I'm not aware of?
Old April 6th, 2016, 01:20 PM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
Did they use a hydraulic press?
Semper Fi!
Old April 6th, 2016, 01:31 PM
sflash868's Avatar
sflash868
Stephan Laputka
1995 D-90 SW
Doubtful. I think they just used a pitman arm puller like I used. Mine was small though. They had much bigger ones but still no luck
Old April 6th, 2016, 01:39 PM
put tension on it with a big puller.
then whack it with a hammer.
it should come off. If it doesn't, whack it again.
Present:
1960 SII 109"- "Red Square"
1984 90 Tdi- "Yamelo"
1988 RRC- "Chewbacca"
1987 RRC- "Chewy 2"
2008 RRS SC- "The Supersofa"
Past:
Old April 6th, 2016, 01:45 PM
broadstone's Avatar
broadstone
'84 CSW 90 '74 NADA III '97 CSW 110
Pretty much what I did. Had a hell of a load on the puller and was ready to see it just explode. Before giving up I then put a long chisel with a taper in between and gave it a good shot, popped right off. Though I really was surprised It popped off.
Patches are for Pirates and pants, not a bulkhead and chassis!
Old April 6th, 2016, 01:50 PM
sflash868's Avatar
sflash868
Stephan Laputka
1995 D-90 SW
What about torching it? Will the mess up the seals in the steering box?
Old April 6th, 2016, 01:58 PM
300tdi convert
Michael Giddinge
Late 80s 110 300tdi
I've removed three or four, one of which I had to resort to using a dremmel tool cutting disc. Didn't take all that long. and assuming your replacing it anyway, nothing lost. The cutter was small enough that I could get in and cut just the pitman arm enough until it popped.
1989ish 110 300tdi (Bella)
1988 LR90 ST 200tdi (Shorty)
1991 D130 200TDi (TBN)
Old April 6th, 2016, 02:33 PM
sflash868's Avatar
sflash868
Stephan Laputka
1995 D-90 SW
You didn't mess up the splines on the steering shaft?
Old April 6th, 2016, 03:33 PM
300tdi convert
Michael Giddinge
Late 80s 110 300tdi
I could just see a bit of a mark on one spline. I didn't grind all the way to the shaft, it popped just short with exception of one spot where I did touch the spline. This was a last resort, but IMHO, less damage then endless banging etc. I had already tried a HD pitman arm puller and considerable hammering.
Old April 6th, 2016, 04:10 PM
I always use two wedges coming from opposite directions in between the box and pitman arm. I have never had much luck with pitman arm pullers.
Old April 6th, 2016, 07:36 PM
sflash868's Avatar
sflash868
Stephan Laputka
1995 D-90 SW
Spoke to the shop. They didn't try hitting it with a hammer. They were afraid they'd be on the hook for a Land Rover steering box and decided it wasn't worth it. haha. I'll try the dealership.
Old April 6th, 2016, 08:06 PM
From a prior thread of the same goddamit problem
Originally Posted by Davis View Post
I got stuck last night trying to remove the pitman arm from steering box on my RRC. I don't think it has been removed in 20 years--I've never taken it off, and I've owned it for 10 years. That sucker was stuck hard, and I know most the tricks on removal. I knew I needed some help and that I needed another tool... so I went to my trusty Harbor Freight. Hey, cheap tools, but some are just great and I have a store near by. I got the Pitman and Tie Rod Puller for a whopping $9.99 (tool number 1752). It would have been $8 if my 20% off coupon wasn't expired. Anyways, it fits fine and paired with an impact gun, I was done in under a minute. Thought THAT was worth passing on. Pitman Arm Puller & Tie Rod Puller
Peace,
C
Price of the tool has gone up though
Old April 6th, 2016, 09:38 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
I've removed these 2x in the past.
Both were easy.
Let the steering box leak oil for a few years before you pull the arm...
Rent my
Old April 6th, 2016, 10:00 PM
jafir's Avatar
jafir
Jafir Elkurd
I used one like this:
It clamps onto the arm so that it won't come off when you hit it with a big heavy hammer.
You can rent one at Autozone.
Old April 6th, 2016, 10:01 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
Ha! I was about to post to use a 1/2" impact gun and a harbor freight pulled! Can't even recall posting the above and what a gas seeing I was quoted! I've removed two other stuck pitman a the same way-- impact gun on puller. Even if puller would break (which it hasn't) they are not expensive from HF. I stand behind this technique...
Old April 6th, 2016, 10:47 PM
87 D110 (Ruby)
Bfh?
Old April 7th, 2016, 07:44 AM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
Bfh?
big fucking hammer
Old April 7th, 2016, 08:50 AM
Originally Posted by 1of40 View Post
big fucking hammer
One size down from the European standard - RBFH and above the regular BH.
Can occasionally but substituted by LR special part number #5318008 or its equivalent large trail rock.
Looks like Lav should be making a hand crafted artisanal bloody knuckles tool kits ...
Old April 7th, 2016, 09:10 AM
tjfslaughter's Avatar
tjfslaughter
thomas
Burbon
One size down from the European standard - RBFH and above the regular BH. Can occasionally but substituted by LR special part number #5318008 or its equivalent large trail rock. Looks like Lav should be making a hand crafted artisanal bloody knuckles tool kits ...
Royally or Real?
Old April 7th, 2016, 09:29 AM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
One reason I do not like the BFH or RBFH technique with the steering box still on the truck is the only room to get a good swing would hit the side of the pitman and really but a wack onto the shaft of the steering box. I know I am not the only one to have this concern... I do agree that the technique is valid as that is the #1 way to get off things like rod ends, but, particularly with my rebuilt Meridian box, I wouldn't recommend a RBFH onto something that also holds oil (I did say Meridian box...I know a stock box doesn't hold oil :-) ). Too much momentum with a RBFH...
Pitman Arm 97 D-90 97Ariesblu Wanted 12 May 20th, 2007 09:35 AM
Pitman arm Abrooks Wanted 1 June 13th, 2006 02:28 PM
Need new drag link & pitman arm !? Rover- Girl Defender Technical Discussions 4 March 23rd, 2006 06:33 PM
Pitman arm Picture Buckon37s Defender Technical Discussions 7 March 4th, 2006 06:02 PM
little piece that steering damper mounts to near pitman arm evilfij Wanted 4 October 5th, 2004 08:55 PM
