Can't get Pitman arm off - Page 2 - Defender Source
Old April 7th, 2016, 09:58 AM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
Ideally, you want to do the 2 hammer method. Like that used to shock TRE's loose.
Use a BFH but brace it on the opposite side with an equally BFH.
Rent my
Old April 7th, 2016, 10:07 AM
broadstone's Avatar
broadstone
'84 CSW 90 '74 NADA III '97 CSW 110
Using a long chisel (I have a 2' one) gives you the ability to use it as a wedge between the pitman arm and steering box like Jimmy said. If it's long it gets you out of the way to actually be able to hit the chisel and drive them apart.
Patches are for Pirates and pants, not a bulkhead and chassis!
Old April 7th, 2016, 10:18 AM
MotoMando
Armando Centeno
1997 Defender 90 SW
I bought a new pitman arm and replaced the old one. I had to cut into the old one until enough tension was release. Good time to convert a disco version of the steering setup if you can. I have a Snap On heavy duty pitman arm puller for sale now.
Old April 7th, 2016, 10:36 AM
Can you rent a hydraulic pitman arm puller?
Old April 7th, 2016, 12:14 PM
97-D90-736
Nick Vogel
1997 D-90 / 2012 LR4
I gots some grief a while back for buying one from London for LR ($200 us). But it didnt slip off like the ones I could get here and I didnt have to beat the shit out of it with a hammer. If you are stuck and need to borrow it, i'll mail it to you. Going to need a big ass impact or long cheater bar though.
Old April 7th, 2016, 01:10 PM
sflash868's Avatar
sflash868
Stephan Laputka
1995 D-90 SW
Dammit, now I seem I like only guy on here who hasn't conquered a stuck pitman arm. Sigh, ok I have a harbor freight near me. I'll go over there this weekend and see what they got. I need the tool anyway in case I need to remove it on a trail for whatever reason. I also don't have a socket large enough for that nut. While I"m there, i'll pick one up.. does anyone know the size of that nut?
Old April 7th, 2016, 01:26 PM
Harbor Freight isn't going to help you succeed .. if its that stuck you need a quality tool. Do you have any tool rental places close?
Old April 7th, 2016, 02:37 PM
sflash868's Avatar
sflash868
Stephan Laputka
1995 D-90 SW
I have Oreillys and Napa. I took a look at their rental section and the tools look meh. I like the one that locks the jaws onto the pitman arm, especially if I'm gonna slam it with a BFH. I'll see what they got. Oreillys sells it for 80 bucks.
OTC 7310A - Pitman Arm Puller | O'Reilly Auto Parts
Old April 7th, 2016, 02:59 PM
FYI you are hitting the arm not the puller.
Present:
1960 SII 109"- "Red Square"
1984 90 Tdi- "Yamelo"
1988 RRC- "Chewbacca"
1987 RRC- "Chewy 2"
2008 RRS SC- "The Supersofa"
Past:
Old April 7th, 2016, 03:10 PM
sflash868's Avatar
sflash868
Stephan Laputka
1995 D-90 SW
Ha yes I'm aware. Still want it on there as good as possible..
Going to look for one of those forks too so I can hammer that. Any ideas on the nut size?
Old April 7th, 2016, 03:15 PM
Ok, just checking
Not sure on the nut size, I never seem to have the socket for them. Air chisel, or a big fat adjustable might get it off.
have to be careful with the fork style as there is a dust seal on the outside of the box that can get damaged.
Present:
1987 RRC- "Chewy 2"
Past:
Old April 7th, 2016, 03:16 PM
scrubs
henery
1974
Youtube I believe
Land Rover Tool Box
Seems like they had a tutorial on this
Hope it helps
Arlo's Avatar
Arlo
Kurt Ohlendorf
1997/130CC
Why removing the arm?
http://www.defendersource.com/forum/...tml#post548845
Old April 7th, 2016, 03:39 PM
fyi - I have obtained the best performance of pullers from turning them with a mighty impact wrench. Just lay on the nut with a 350+ ft-lb impact wrench until either the part comes off or the puller explodes
Old April 8th, 2016, 06:44 AM
Gren_T's Avatar
Gren_T
Gren Thomas
1985 90 300tdi auto
I've blown the seals on my 10T hydraulic puller attempting to get the arm off the steering box just to replace a 10 joint I ended up cutting that arm off, now i just change the joint on the car 30mins and all done.
Arlo had a nicely engineered setup but this shows all you need to do it :DA1125 Land Rover Defender Steering Drop Arm Ball Joint Removal Tool | eBay
regards
Gren
Pitman Arm 97 D-90 97Ariesblu Wanted 12 May 20th, 2007 09:35 AM
Pitman arm Abrooks Wanted 1 June 13th, 2006 02:28 PM
Need new drag link & pitman arm !? Rover- Girl Defender Technical Discussions 4 March 23rd, 2006 06:33 PM
Pitman arm Picture Buckon37s Defender Technical Discussions 7 March 4th, 2006 06:02 PM
little piece that steering damper mounts to near pitman arm evilfij Wanted 4 October 5th, 2004 08:55 PM
