Can't get any power to my dash - Defender Source
Old January 8th, 2015, 01:29 PM
Sheffieldadz
1992 defender 90
Hi guys, my mates been sorting a few things on my defender and now all of a sudden my defender has lost all power but yet the battery is charged I've checked all fuses, relays tried looking for inline fuses and just can't get any power even my alarm hasn't got power
There's no lights on the dash at all and my alarm hasn't got power to it either but yet my battery is fully charged it also got no power to the ignition so it won't start
My mate was only having a look at my indicators has when i indicated right both my front indicators came on then all of a sudden my power is lossed he has had the clocks out aswell but can't see anything wrong
Please can someone help thanks a lot
It's a defender 90 1992
Old January 8th, 2015, 01:31 PM
check ignition switch.
Old January 8th, 2015, 01:32 PM
Check the main ground and power cables from the battery and from the engine to the chassis.
Old January 8th, 2015, 01:41 PM
Fuses in the engine bay?
Old January 8th, 2015, 01:58 PM
Your mate has caused you a bunch of trouble ain't he?
Maybe you should only give him the beer AFTER he's done the job, not before...
Old January 8th, 2015, 02:33 PM
Sheffieldadz
1992 defender 90
I don't think it could be ignition because my alarm hasn't got power at all and it's not flashing,
I've checked the Earth straps and one was loose but there in poor condition also can anyone tell me how many Earth straps there is and were they should be connected
Old January 8th, 2015, 02:45 PM
Some alarms control power to the ignition. Is that what you have???
Old January 8th, 2015, 03:51 PM
Sheffieldadz
1992 defender 90
Hi not sure on my alarm as it was already on the defender but that's not even flashing at all or working when I press the key fob, could the earth wire have come off on the alarm?
Old January 8th, 2015, 06:00 PM
ron's Avatar
ron
Ron
1994 NAS Defender 90
ah is the battery dead? keep the jumpers on then try key.
good luck with your search
Old January 8th, 2015, 07:02 PM
I hate alarms. Especially aftermarket, dealer installed alarms.
Old January 8th, 2015, 07:16 PM
Ignotus
gene
1960 109, w/200TDI
Are both cables tight to the battery? Is the ground cable tight to engine or frame? The + cable should go to the starter is it tight? From there a brown wire goes to the ignition switch, is it tight? Get a test lamp and figure out where the power goes and doesn't go.......get a manual.......HTH
Gene
1960 109
1960 88 Ignotus
Blog;
Old January 9th, 2015, 08:12 AM
Sheffieldadz
1992 defender 90
my mates just played around with the auto watch alarm box and it all started working and now it's all just stopped again no power at all ��
Thanks everyone
My next problem is;
When I indicate right all my indicators come on like I have the hazzards on
Old January 9th, 2015, 08:51 AM
rankar's Avatar
rankar
97 SW #2236 (Maggie)
Do you have led turning lights?
Old January 9th, 2015, 09:50 AM
Sheffieldadz
1992 defender 90
Yeh ive just put led indicators in well the bulbs
Old January 9th, 2015, 10:29 AM
Switch them back and do a little searching regarding LED flashers.
Old January 9th, 2015, 10:32 AM
So I was right?
Old January 9th, 2015, 11:02 AM
rankar's Avatar
rankar
Yeah you were Josh. You da man.
dash
How can I get more power for freeway driving from my 3.9 V8 Jcwhancock Defender Technical Discussions 41 December 14th, 2014 04:50 PM
How do these get into the USA and get sold? Grover Misc. Chit-Chat 33 April 23rd, 2012 01:15 PM
Can it get any better! Mike Hippert Defender Technical Discussions 14 April 4th, 2005 04:32 PM
So, if you could get any accessory you wanted.... Hans Misc. Chit-Chat 18 February 17th, 2005 09:47 AM
???still can't get the trany unbolted from the engine???? kit Defender Technical Discussions 4 October 23rd, 2003 03:20 PM
