cant get 95 RR SWB out of park !! - Defender Source
Old April 9th, 2009, 01:21 PM
jimmybuffett's Avatar
jimmybuffett
Tom
Hell On Wheels....
i posted a thread earlier about not being able to get my rover out of park. i changed the brake light switch and still no luck. i know theres a inhibator switch on the tranny , but not sure if its that . the only other thing when i stepon the brake the SRS light on the dash flashes. the brake light aslo seems to fad a little bit( the brake light has been on as long as i can remember) i also checked all the abs/srs fuses . thanks for any and all help..
Old April 9th, 2009, 02:19 PM
revor's Avatar
revor
Keith Kreutzer
Old beat up 110
Check and double check everything, the solinoid that pins the shifter may in the end be what is causing you the trouble. IIRC it's on the passenger side of the shifter and has a couple wires. The Solinoid needs 12 volts to pull. The Key has to be on and the prake switch depressed there is a relay (on the right side footwell in a Disco) that energizes the solinoid. That relay or the power going to it could also be the problem.
Keith
Big, Red and ... aaa Red..
Old April 9th, 2009, 03:35 PM
kellymoe's Avatar
kellymoe
kevin
defender 130
I thought there was a switch under the brake pedal arm that is activated when you depress the brake. It is plastic and has a tendency to break at the worst times. The same happened to me in my 94 Disco and I could not take it out of park. Check it out. It's a plastic plunger looking switch.
Old April 9th, 2009, 03:52 PM
Kellymoe, that was my suggestion and he said he replaced it.
Old April 9th, 2009, 05:25 PM
kellymoe's Avatar
kellymoe
kevin
defender 130
Ah, I see it, the brake light switch he replaced, sorry.
Is there a shifter film or sheet that may have gone bad? It slides with the shifter at it's base. If it goes bad it can cause similar issues.
Old April 9th, 2009, 05:35 PM
Roverowner's Avatar
Roverowner
Brian Love
95/Disco
This might be one for the "did that already" but I once had the same problem and I had something physically blocking the shifter from moving. Is it maybe something like what happens when you park on a steep hill and the transmission is 'locked'? That is my two measly contributions....good luck.
Inspirational Thought of the Day
Some people are like Slinkies ...
Not really good for anything, but they still bring a smile to your face when
you push them down a flight of stairs.
1995 Discovery
Old April 9th, 2009, 06:09 PM
Roverowner. He said that his brake lights don't come on, but I have seen a couple discos with pennies preventing them from leaving park.
Old April 9th, 2009, 06:43 PM
Roverowner's Avatar
Roverowner
Brian Love
95/Disco
I was about two minutes from sticking a rag in place of the fuel cap and lighting it when I finally saw the black pen keeping me from going in to Drive...
1995 Discovery
Old April 10th, 2009, 10:29 AM
ajtbussen
A J Bussen
1997 D-90 ST
Have you reset the ABS system? There is a pink plug located under the driver seat and you need to short two of the wires. Search on rovers north forum for the procedure. My 2 cents.
AJ
If it aint moto it's worthless.
Looking for '95 D-90 & '95 RR Classic owners manual PMKColorado Wanted 3 August 23rd, 2009 09:27 PM
Not thinking right - '95 SWB or '96 4.6 - Ahh PMKColorado Defender Technical Discussions 25 July 24th, 2009 11:39 PM
1995 swb rr jimmybuffett Defender Technical Discussions 0 June 12th, 2009 11:04 AM
1995 swb rr tranny problem jimmybuffett Defender Technical Discussions 2 April 2nd, 2009 05:39 PM
95 Rrc Swb Roverlab For Sale - Vehicles 5 May 20th, 2008 07:33 AM
