Cannot pick up rpm signal - Defender Source
Old August 17th, 2014, 02:17 PM
Qatari Land Rover
Abdulla
2010/Defender 110
Hi All
I have a 2010 Defender 110 had a puma 2.4tdci engine
And I have replaced it with Chevy V8 LS Based 6.0L and a 4L80 trans, the problem I'm having right now is the Rpm signal I'm trying to make the original instrument cluster working please advise .
Ps is there a signal converter that I can use to make the rpm work ?
Old August 17th, 2014, 07:47 PM
red64chevelle
Daniel Smith
86 110 300TDI,16 Disco Sport
With the distributorless ignition on the LS engine, I think you are going to need this:
http://www.msdignition.com/Products/...Ignitions.aspx
I have read that will work with a normal gas tach, I cannot say for certain that it will work with a diesel tach. The diesel ones are normally driven off a terminal on the alternator (at least for a VW diesel or LR TDI)
Hope this helps
75% of all Land Rovers ever made are still on the road...
the other 25% at least made it home.
Old August 17th, 2014, 07:59 PM
Qatari Land Rover
Abdulla
2010/Defender 110
i have used something similar : http://www.dakotadigital.com/index.c...rod/prd825.htm
but i can't find the RPM wire
Old August 17th, 2014, 08:16 PM
Tach signal typically comes from the alternator. On most alternators there is a terminal labeled "W".
This is the tach signal source. Not sure how a tdci gauge and an LS alternator will be as far as synch but your gauge should give you a reading if you connect the signal wire to the w spade on the alternator.
Old August 17th, 2014, 08:59 PM
Wow! Most people in the US would pick a Puma motor over a GM motor. Guess location is everything in this case.
Old August 17th, 2014, 09:10 PM
In that part of the world the desire is the biggest V8.
Old August 17th, 2014, 09:13 PM
Qatari Land Rover
Abdulla
2010/Defender 110
unfortunately in my Country even my region ( middle east ) there is lack of expereince a round the land rover defender in general in my case i was forced to change my engine because the dealer in my country broke my new puma engine after only 20000km !!
after an investigation was made by a court order the dealer declared that he don't have experienced mechanic for such a car and don't have even a spare parts
Old December 15th, 2015, 02:57 PM
Defender110Pilot
1986/Defender 110
Were you ever able to resolve this?
Damn! Cannot figure out what is wrong with the lights! solihul Defender Technical Discussions 11 October 26th, 2017 07:04 PM
cannot help it - NEUTERED DC100 paulb Misc. Chit-Chat 0 October 11th, 2011 07:25 PM
Wired.com article, "you cannot have these cars" hillstrubl Misc. Chit-Chat 0 April 11th, 2011 10:10 AM
Tach signal pick up MudD1 Defender Technical Discussions 2 September 4th, 2010 06:04 PM
Cannot UPLOAD PHOTOS: norros Support & Suggestions 12 October 6th, 2005 08:25 PM
