Cannister - Defender Source
Old May 7th, 2005, 05:28 PM
gearco
James T. Johnston, Jr.
1986 D110
Cannister
My 1994 D90 #999 stalls if I connect the vacuum line from the plenum to the cannister behind the right front headlight. Runs fine if I disconnect it. Does this mean my cannister is stopped up?
Old May 8th, 2005, 09:47 AM
Have you tried disconnecting any of the other lines?
Old May 8th, 2005, 12:05 PM
gearco
1986 D110
Canister
No I haven't. Should I?
Old May 8th, 2005, 01:44 PM
Hmm thinking about it I would try removing the positive crankcase ventilation breather filter. It is the grey canister sticking up out of the passenger rocker cover, it also has a hose coming out of the top. The filter can get clogged, it can be cleaned with maybe gas, or you can just get a new one and replace it.
Here is a pic of it
http://www.northeastbritishparts.com/.sc/ms/bdd/1103491306227003/9/nc/ee/6107/FLAME%20ARRESTER%20^2F%20BREATHER
NAS D110 AC/Heater Ducting 3rovers Defender Technical Discussions 13 May 31st, 2009 09:38 AM
Charcoal Canister/Evaporative emission control Antonios Defender Technical Discussions 8 March 19th, 2006 10:35 AM
Stupid vacuum hose Mike Hippert Defender Technical Discussions 7 November 9th, 2005 09:00 PM
