Can you put this together? - Defender Source
Old June 21st, 2015, 01:15 PM
ymc226
Lawrence
1995 D90 SW NAS
1995 D90 NAS
It first started with my engine making a tapping sound at idle that increased in speed when I stepped on the gas but soon disappeared or became unnoticeable due to a change in frequency.
Anyway, my local mechanic removed the valve covers and intake plenum and removed/cleaned the rocker arms and oil passages and noticed no unusual wear that would be detrimental to continued use. He individually held down each lifter and saw oil fill appropriately. He halfway suggested that I could replace the lifters for about $1000 but that would not guarantee solving the issue so I didn't.
Nothing changed for a week. Now since yesterday, gradually the tapping sound has gone away but my engine now sounds like a chopper/motorcycle without a muffler, much louder and rougher, especially with acceleration and with exhaust fumes more evident in the cabin. None of the warning lights are lit.
Can the 2 issues be tied together? I'm definitely not going to drive it once I get home and take it to a mechanic.
Old June 21st, 2015, 01:22 PM
speedpin's Avatar
speedpin
1985 130 Gen IV
Exhaust leak... wheel exhaust is cool, start up, check for leaks at headers/joints with back of hand. Careful gets hot quick. Can use a rubber hose up to your ear like a stethoscope.
------ Follow up post added June 21st, 2015 01:23 PM ------
Sound goes away as everything expands and seals better.
~ Semper Fidelis ~
Old June 21st, 2015, 01:31 PM
ymc226
Lawrence
1995 D90 SW NAS
Thanks Adam. Can it be a partial leak as the wheel exhaust is still spewing out hot gasses?
Old June 21st, 2015, 01:36 PM
speedpin's Avatar
speedpin
1985 130 Gen IV
"When" exhaust
Yes partial Leak. But if it sounds like a motorcycle its a good size leak.
~ Semper Fidelis ~
Old June 21st, 2015, 05:14 PM
Or throw some seafoam in and you'll visually see any exhaust leaks real quick.
Old June 21st, 2015, 10:05 PM
Departing90
Sasha
95 D90
90% of the time its the triangular gasket between the header and pipe.
The tapping sound is a completely seperate issue. Often times its gunk buildup due to infrequent oil changes. Use engine flush "follow directions on bottle" or 2 quarts of atf, let idle for 30min then flush and refill with fresh oil and new filter. If knocking sound still persists then you have mechanical damage and would ideally need to change the lifters as a set. Most prob 2 or 3 are bad. Ive changed just tye affected lifters before for cheap customers. If your engine has over 80k you would also need to pay close attention to the cam to make sure tye lobes are in spec.
Old June 21st, 2015, 10:36 PM
Greg S
Greg Sutfin
1986 90
The ticking and motorcycle noise are one and the same from the sound of it. When you have just a small exhaust leak it is a very definite "tick,tick" and sometimes goes away as the manifold gets hot and parts expand, tightening up and sealing. The leak has now gotten bigger so is much noisier.
As mentioned, most likely the manifold to header gasket but could also be manifold to head gasket.
Help Put Together a Seller's Guide Sticky - For Sale Vehicles rijosho Misc. Chit-Chat 18 June 29th, 2015 08:23 PM
Anyone have limb risers already put together for a defender? jcb-memphis Wanted 5 April 24th, 2013 10:55 AM
Help me put together a Spring/Lift Measurement Database… LRNAD90 Defender Technical Discussions 9 April 15th, 2008 01:21 PM
Plz Tell me ECR can put this in for me... trislerjw Misc. Chit-Chat 16 February 22nd, 2007 10:02 PM
HELP!! I can't put my tranny in gear... JRowe Defender Technical Discussions 1 October 12th, 2003 12:07 PM
