Can Somone Confirm - VDO - Defender Source
Old December 31st, 2012, 11:26 AM
gonzanc's Avatar
gonzanc
Nick
'95 4.2L NAS D90
All,
I have scoured the forum and come up with the parts to do the VDO gauge swap on my 1987 Defender 90. I am about to submit my order, but wanted to make sure I was ordering the right parts before I did so....here is what I have compiled
Fuel - 301-105
Temp - 310-1052 (kit includes various parts I will need)
Clock - 370-155
Speedo - 437-155
Harness for speedometer - stc4637
Speed Sensor - ybe100540 OR ybe100530
My questions is, can someone confirm that the ybe100540 will work for my 87 D-90? I have the LT77 and 2.5td
Thank you
Old December 31st, 2012, 11:36 AM
navydevildoc's Avatar
navydevildoc
Neill Thornton
The speed sensor actually goes into the transfer case. So as long as you have an LT230 under there you should be good. I'll be under the Antichrist later today, I can take a look and see what I have since I have the same speedo.
Old December 31st, 2012, 11:39 AM
gonzanc's Avatar
gonzanc
Nick
'95 4.2L NAS D90
Doc, thank you! As someone on here put it best "welcome to the party that never ends"
Old December 31st, 2012, 02:18 PM
Naplm00
Matthew
Not sure if you are running a diesel or not: but in addition
EGT 310-153
Boost 150-1041
Water temp sender 323-417
Diesel Tach 333-158 (0-6k rpm)
Old December 31st, 2012, 02:24 PM
madcowdungbeetle
Carter
To simplify things I believe you can use a CJ-7 speedo cable.
Old December 31st, 2012, 02:47 PM
gonzanc's Avatar
gonzanc
Nick
'95 4.2L NAS D90
EGT 310-153
Boost 150-1041
Thank you! I am running the 2.5td, but I believe the temp gauge/kit (310-1052) comes with a sender and adapters to make it work. i believe the sender that comes in the kit is (323-095)
Old December 31st, 2012, 02:53 PM
Naplm00
Matthew
Cant remember exacly but I think I was going to buy the 323-417 because it is M16x1.5. The same as the stock sender location on a 200TDI
With the 323-095 (1/8-27 NPT) you will have to make a bushing or drill/tap somewhere
------ Follow up post added December 31st, 2012 02:56 PM ------
Use this page for refrence on the senders: http://www.egauges.com/vdo_send.asp?...=250F_120C_VDO
Old December 31st, 2012, 02:57 PM
gonzanc's Avatar
gonzanc
Nick
'95 4.2L NAS D90
According to egauges.com, the 310-1052 kit come with a 1/8-27npt to M16x1.5 adapter bushing that allows you to use 323-095. I believe it is cheaper to buy the kit than it is to buy the gauge and sender separately.
Old December 31st, 2012, 02:58 PM
Naplm00
Matthew
bingo
1k posts!
Old December 31st, 2012, 03:31 PM
navydevildoc
Neill Thornton
Nick,
My Tdi has YBE100540 on it... also you will need to find the connector that mates to the sensor. It's the same connector that goes to a NAS rear brake light. I forget where I got it from, but without it you will be having a bad day. I found a pigtail version that only had about 6 inches of wire on it, so I put a molex connector at the bare wire end and then made my own cable to run up to the speedo.
You will also have fun programming the speedo for the sensor. Find a good GPS unit that shows speed in real time and it will take a good 30 minutes to get it dialed in due to VDO's really dumb method of programming it.
VDO SPeedo roverboy Defender Technical Discussions 69 March 1st, 2015 10:35 AM
Speedometer cable mod for VDO - shop? mgrgpg Defender Technical Discussions 20 December 27th, 2013 11:57 AM
Source for VDO gauges loykd Defender Technical Discussions 4 February 23rd, 2005 08:08 AM
VDO speedo for sale vlocci For Sale - Parts 3 May 2nd, 2004 12:38 PM
