Pulled my 1995 NAS D90 ST out of the garage after the winter and found this part on the ground in the garage. Over the winter I changed out the battery and pulled all the accessories out from under the seat in the battery compartment to clean everything. There may be a chance i knocked this part loose.
Anyhow the part is RED in color and made out of a tiny piece of sheetmetal. It doesn't look like the part is damaged as there is no crack lines and the part coloring is intact on all the edges.
It looks to be possibly a wire-stay or hold-down of some sort and most likely hooks into something.
This will drive me crazy until i get to the bottom of it
Anyone out there recognize this clip?
Thank you
Thank you
