Can someone do a favor for me? - Defender Source
Old March 28th, 2008, 11:36 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
I was hoping that somebody could trace the rear wheelwell opening on a piece of cardboard and mail it to me. Without the fender or up tight to the actual body line. I will pay for the shipping of course.
I basically need a drawing of the rear well. Any help is appreciated. Thanks
2009 King of the Hammers
BUCK Wild Racing
Driver: Me
Co-driver: Pat Quirk
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old March 29th, 2008, 12:14 PM
Captain Spalding's Avatar
Captain Spalding
Captain Spalding
You're looking for the sheet metal or the plastic wheel arch? (maybe they're the same, I don't know.)
Old March 29th, 2008, 01:59 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
The metal, not the plastic. Thanks
BUCK Wild Racing
Driver: Me
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old March 29th, 2008, 04:33 PM
Shane@EVS
Roverhybrids
I'll provide the template if you let me in on the plan!
Old March 30th, 2008, 12:05 AM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
Done. I'll PM you with all the details. Thanks!!
BUCK Wild Racing
Driver: Me
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old March 30th, 2008, 09:53 AM
WhiteD90's Avatar
WhiteD90
Johnathan Tisdale
93 110, 90 RockRR buggy
are you replacing your tub?
Old March 30th, 2008, 12:23 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
yes and no. Sorta, mostly.
BUCK Wild Racing
Driver: Me
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old March 30th, 2008, 01:12 PM
Dave are you running for office? You are sounding like a Politician.
Old March 30th, 2008, 02:11 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
I believe in hope. Hope for change. Because change is the future, and the future is ahead of us, where the past is behind us. So hope for the future of change, and hope to change the future. There must first be hope, and then change, but you can not have hope without change. Elect me.
I don't mean to be so cryptic. It's just that there is not much progress and describing what I am doing is very difficult. It's getting a face lift. I do have a few pics of it naked though.
ID:	12811   Click image for larger version
BUCK Wild Racing
Driver: Me
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old March 30th, 2008, 03:48 PM
WhiteD90's Avatar
WhiteD90
Johnathan Tisdale
That's OK, go ahead and try. Several of us are interested in a rear re-design and would like some creative input.
Tis
If you have some, can you send me a couple front shots like aproach angle side shot and panhard frame side mount. How much do you think you moved your front axle forward and how much total lift do you have?
Old March 30th, 2008, 04:38 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
Tis
What I am doing to rear is difficult to explain. It involves tube, panel, dovetail, all with a stock rover look to it. I will keep you in the loop as progress is made. I know you are interested.
As to your questions, the front end was moved forword 3in. I think I have 4in of lift. I run that much more for ground clearance than necessity.
Here are pics of the front approach angle (90 degrees) and the panhard. I used the stock mount but cut and welded it to make it closer to the frame. Be VERY careful if you plan to weld a new bracket to the rover frame. No matter how big you build the new bracket, I have seen them peel away from the rover frame like a tuna can lid, twice.
One last thing, with the way I cut the front in the first pictures, the tire comes within about a quarter of an inch from hitting it at full stuff with the tires turned. I have over 40 degrees of steering so that has something to do with that, but this is why I warned you that there is not a lot of alternatives to cutting if you want to run tires this size.
ID:	12813   Click image for larger version
BUCK Wild Racing
Driver: Me
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old March 30th, 2008, 07:29 PM
WhiteD90's Avatar
WhiteD90
Johnathan Tisdale
Cool, thanks. I had my panhard modified once since it had interference problems originally with the 9"s.
I'm somewhere in the middle, I'd like to run a 39" but like a low slung rig too. I need the wheelbase as much if not more than I need the extra tire height. Your cut looks good, but one thing I want to do is retain a trimmed flare for the "stock" look. I might be able to do that with a moderate cut like yours or Bill's in the front.
Definately keep me posted on the rear...I haven't seen a design yet that or thought of one that makes me ready to cut into the rear tub.
Old April 2nd, 2008, 01:12 PM
WhiteD90's Avatar
WhiteD90
Johnathan Tisdale
saw your truck in this month's Peterson's. You re-doing the exo so they can do another article referencing your rig?
Tis
