Can one person lift a motor out of a D110 rolling chassis without a hoist? - Page 3 - Defender Source
Old April 27th, 2009, 08:23 AM
Gkase's Avatar
Gkase
George Kase
1983 110 200Tdi CSW LHD
Here's one way to do it...quoted from this web page: http://www.academymusicstudio.co.uk/.../landrover.htm
"The old engine removed from the 1971 Land-Rover without an engine crane!
Here's how I did it:
Dismantle the donor land-Rover down to rolling chassis on the lawn, remove prop shafts & handbrake assembly. Then jack the chassis up slightly under the gearbox cross member just enough to take the weight. Then using a power saw, cut the chassis in the middle, just behind the jack. Push the rear chassis complete with axle, springs & wheels out of the way. Lower the jack & pull it firmly out of the way (watch your toes). Undo the gearbox mounting bolts & remove gearbox from engine. this can be lifted out quite easily single handed. Undo the engine mounting bolts, then using a plank of wood, lever the engine from under the front of the crankshaft. The engine then falls out onto the lawn. Now move the front part of the chassis wheelbarrow fashion, out of the way........ Then borrow John Bolt's engine crane, to drop the engine onto a miniature railway truck, so as to remove offending engine from lawn before anyone sees the mess! Finally, mow the lawn where the Land-Rover has been stood & repair the bald patches of lawn where the radiator coolant killed the grass.....!!!!"
I don't know...sounds like a plan to me!
George
Old May 3rd, 2009, 12:49 AM
Long story short, I wussed out and the mechanic up the road let me borrow his after he said he had no desire to do the motor in the lotus (I could not figure how to do the lotus motor without a hoist unless I dropped it through the bottom which requires removing the transmission), but I could borrow his crane as he never uses it.
The way I was going to do it was to jack up the frame really high, put two 4x4s under the engine supported by jackstands on either side and then lower the frame and pull the frame out the back.
Ron
110, d110, motor
Rolling chassis with drive train $1000 bitz The Flea Market 0 August 12th, 2009 08:48 AM
D110 V8 Galvanised Rolling Chassis globallandrovers The Vendors Loft 0 July 5th, 2009 06:24 PM
Rolling chassis w/ 4.0, etc tbmcneill For Sale - Parts 11 August 26th, 2004 12:12 AM
109 rolling chassis, drivetrain bulkhead $500 evilfij For Sale - Vehicles 1 June 20th, 2004 07:50 PM
Rover Build - Rolling Chassis ?s Jase Misc. Chit-Chat 14 March 4th, 2004 10:32 AM
