Can limited slip be added to a stock 3.54 diff? - Defender Source
Old July 14th, 2015, 11:08 AM
ionfender's Avatar
ionfender
IO
94 NAS D90, #1379 (SOLD)
Can a stock LR 3.54 differential be modified to make it limited-slip?
Old July 14th, 2015, 11:11 AM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
Yeah, trutrac or ashcroft ATB can be added
Old July 14th, 2015, 12:12 PM
LRNAD90's Avatar
LRNAD90
Scott T
1995 Defender 90 ST
A lot of potential for misunderstanding here, and based on the way the question was asked, just wanted to make sure you are clear that..
  • The stock 'differential' cannot be modified to make it a limited slip, it needs to be replaced..
  • The 'third member'(or differential carrier) can be modified to create a limited slip differential assembly by installing any number of limited slip or locking differentials (as noted above) in it..
  • The stock 3.54 Ratio Ring and Pinion set can be used with most if not all of these differential options..
~Scott T.
'95 D-90 ST - AA Yellow
Old July 14th, 2015, 12:20 PM
ionfender's Avatar
ionfender
IO
Ok, makes sense. Thanks for the clarification, Scott.
Old July 14th, 2015, 12:39 PM
If you buy new, get the Ashcroft ATB.
Old July 14th, 2015, 01:49 PM
ionfender's Avatar
ionfender
IO
Red90 - Have to pick your brain on that. Why the Ashcroft versus the Trutrac?
I should also mention that my off-road use will be fairly limited. My 90 is primarily going to be a fun driver with some off road use for hunting/fishing...nothing too extreme at the moment.
Old July 14th, 2015, 02:21 PM
It uses a better designed and is about the same cost. They also have great service and warranty support. Eaton has none.
If you can find a used one, a Truetrac is fine, but if buying new, you might as well get the better one.
Old July 14th, 2015, 02:32 PM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
Always go Ashcroft when possible.
Old July 14th, 2015, 02:36 PM
drdread's Avatar
drdread
AL
'94 NAS 90 SW
Ashcroft was cheaper when I was looking and had much better reviews. Solid device
1994 Silver DEFENDER 90 NAS SW
Old July 14th, 2015, 03:11 PM
ionfender's Avatar
ionfender
IO
Ok, I'm on the Ashcroft bandwagon. However, the rear third just came off and it has a trutrac in it (I guess I got half lucky...no Ashcroft, but at least it had something). So if the existing trutrac is in good shape and fits the new diff. I'm going with the trutrac for now.
Nonetheless, appreciate the recommendation for what to go with in the future!
Old July 14th, 2015, 03:12 PM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
Trutracs are fine, nothing to complain about!
Old July 14th, 2015, 05:07 PM
down_shift's Avatar
down_shift
Russell
94' D90 ST & 06' LR3
And that they are. I'd like to hear some reasons why Ashcroft's LSD is supposedly superior.
Old July 14th, 2015, 05:20 PM
Angus's Avatar
Angus
Mike Ferguson
1994 Defender 90
6 pockets versus 3 for the TT, higher torque bias, and I feel better quality overall. IMHO.
Angus
Old July 14th, 2015, 05:29 PM
flippedrover's Avatar
flippedrover
Tyler
'94 D-90
Might want to save the money if you aren't going to be doing much off roading. I have kept up with fully locked trucks in the past with my open diffs with little problem.
Jimmy Buffett
Old July 14th, 2015, 05:39 PM
JackW's Avatar
JackW
Jack Walter
1966 109 SW Diesel
I've been running a TruTrac for over 15 years - its been in three different vehicles (Discovery 1. RRC, D-90) and its never had an issue. I don't do the hard core rock crawling but I've been through most of Tellico, all of Beasley Knob and all of Uwharrie along with many other off road excursions. The Trutrac performs very well for what you describe your needs are. Its a good unit. I have no experience with the Ashcroft but the Trutrac should suit you very well.
Old July 14th, 2015, 09:28 PM
LuisC's Avatar
LuisC
Luis Constantin
98 Disvovery 1 LE
X2!!!
Black Rhino Lives Matter
Old July 14th, 2015, 09:49 PM
ionfender's Avatar
ionfender
IO
Luis & Flipped - I agree that I really don't NEED the LSD. However, I was swapping thirds anyway, and in the process we found a surprise trutrac in the in the old diff. that we took off. So I figured what the hell, put it in the new one. It's only costing me what I could have sold it for.
Ashcroft Limited slip diff for LT230 Rocky Defender Technical Discussions 19 June 20th, 2015 09:10 AM
Limited Slip or Locking Differential petminded Defender Technical Discussions 70 January 1st, 2015 12:35 PM
Can anyone confirm that a 95 Disco 1 came with a rear limited slip CDeWan Defender Technical Discussions 7 January 22nd, 2009 03:49 PM
Truetrac Limited slip Anyone want to let one go? CDeWan Wanted 10 November 6th, 2008 06:53 PM
