can I use any Dana 60 cover ? - Defender Source
Old June 8th, 2010, 08:56 AM
artm
Arthur Maravelis
97 SW
Need to replace the Salisbury cover. Will any Dana 60 work? I ask because I see different applications for the Dana 60 that look different.
Can I use this:
http://www.the-jeep-guy.com/AXLE%20&...aw%20Cover.JPG
or this:
http://www.amazon.com/1966-UP-Dodge-...6000128&sr=1-5
I don't want a rock beater, just a basic cover, trying to avoid chrome although they're apparently the cheapest .
Old June 8th, 2010, 09:33 AM
yup-Mass salt eat yours up ?
Old June 8th, 2010, 10:03 AM
artm
Arthur Maravelis
97 SW
Oh, no...it can't be something as simple as salt. This is Rover world where the most stupid things are common.
I had an ongoing leak in the cover so took it off, cleaned it up and RTV'd it back on. Let it sit for a few days to cure and went to refill it yesterday. Well, I'm threading the fill plug and I get no resistance - again. This happened the last time I changed the oil and it dropped right in, hence my need to replace the cover.
So, I had another plug and tested it on the cover while it was off and it took fine. Well, when I tried it on the installed cover, as I said, little resistance. Teflon taped it and got it somewhat snug but it was a bit deep. Remember that.
Now I'm swapping trucks out of the driveway, pull the 110 all the way in, am about to put a pan under it to see if it still leaks and what do I find? NO FILL PLUG. Plus, the fill hole was bent.
Yep, the diff carrier hit the plug and dropped it inside. WTF?! All that work undone by another stupid fill plug. Took the cover off again and the fill plug showed on small nick, so no damage done - except to the cover. Too bad as that RTV really took hold, it was a bitch to pry the cover off this time.
Just when I thought I was having a great day - what with the 90 passing inspection (always a trying time) - Rover hell pulls me back down!
Old June 8th, 2010, 01:11 PM
revor's Avatar
revor
Keith Kreutzer
Old beat up 110
If you don't need a heavy duty version go to the Ford dealer and get one for the front of a '97 F350 4x4. They are thicker than the Salisbury versions as a bonus.
D60 covers use 3/8 bolts and Salisbury use 10MM so you may have to clearance the holes. If the cover uses Sockect head cap screws the heads are not the same size 3/8 vs 10MM so if they are counter-bored you could run into trouble.
Keith
Big, Red and ... aaa Red..
Retrofit's Avatar
Retrofit
Pat
1984 110 CrewCab 200Tdi
Same thing ! I got an ARB cast iron one and fitted right in there. I like the magnetized dipstick and easy clean up plus its a real solid cover .
My 0.02$
Pat
Kirk Lazarus, Tropic Thunder
Old June 8th, 2010, 02:03 PM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
Too funny, I was just going to ask the same question!
Semper Fi!
Old June 8th, 2010, 02:53 PM
slorocco
Dan Prasada-Rao
1963, 109 Station Wagon
I've purchased two different Dana 60 diff covers from two different manufacturers/vendors over the past year. Put one on the front Salisbury and one on the rear Salisbury, both worked fine, no problems. I'm also using the Dana 60 lubelocker diff cover gaskets, so far so good on those as well.
Old June 8th, 2010, 03:49 PM
brn24whl's Avatar
brn24whl
Eric
1994 RRC SWB
My 0.02$
Pat
Thanks for the info I had been wondering if it would fit. I just ordered one should be here late week.
Thanks again
Eric
Eric Riston
1-800-533-2210 ext 231
Direct Line 518-539-2231
Old June 8th, 2010, 03:50 PM
artm
Arthur Maravelis
97 SW
Keith- Thanks but I'm finding this cover with 12 bolts not 10 as here:
http://www.partsgeek.com/catalog/199...ial_cover.html
Dan- Can you list from whom you purchased and what? I only need rear but others may find the front useful. Thanks for the lubelocker plug. I am definitely sick of scraping!
Old June 8th, 2010, 05:43 PM
Hoosier's Avatar
Hoosier
Chris Hinkle
More than I need
For a front salibury, you need a cover with a higher fill hole than on the rear - function of the way the oil is sprayed. Also I ended up putting my axle breather on the diff cover (original axle had it that way) - if you do you need to put a splash guard on the inside to keep oil from being pushed up the breather.
Old June 9th, 2010, 12:06 PM
revor's Avatar
revor
Keith Kreutzer
Old beat up 110
It has to be the Front axle, that's the rear, a 10.25" Sterling.
Keith
Old June 9th, 2010, 01:42 PM
exmod110's Avatar
exmod110
Don Lang
Keith, have you used the ford front on a sals rear? I looked at one and compared it to the sals orig... there is a differance in the depth of the ford one compared to the sals one.... the ford one was shorter and might hit the crown gear??????
unless the one I looked at was from a different year....
Did you by change keep the part #?
85 exmod 110 rhd 300tdi
Old June 9th, 2010, 01:54 PM
My friend went ARB on his Salisbury.... http://www.arbusa.com/Products/Diffe...-Cover/66.aspx Watch the video...
Old June 9th, 2010, 02:16 PM
PN and cost on the ARB unit?
Old June 9th, 2010, 02:29 PM
brn24whl's Avatar
brn24whl
Eric
1994 RRC SWB
Ron I ordered one yesterday it should arrive today I will let you know the part number if it works.
Eric
Eric Riston
Old June 9th, 2010, 03:35 PM
revor's Avatar
revor
Keith Kreutzer
Old beat up 110
No part number in memory but it's a straight up F350 4x4 cover 1997.
No issues with the crown wheel, it also eliminates the hump at the bottom of the sump like on the Sali cover that I always tend to dent.
I've never bent a Ford cover but then I don't go backwards very often on the trail.
Keith
Old June 9th, 2010, 04:22 PM
http://www.arbusa.com/uploads/PDF/ac...evroletGMC.pdf
PN 0750001
There is something required for the bolts. Not sure the details... They might be a different thread, so you need to get your own.
------ Follow up post added June 9th, 2010 02:26 PM ------
Apparently.... http://www.defendersource.com/forum/...d.php?p=117251
My friend mentioned that the M10 allen head bolts are a tight fit in the cover and can do with a slight turning of the heads, at least the bolts he purchased.
Old June 9th, 2010, 05:08 PM
artm
Arthur Maravelis
97 SW
This one looks good. Right shape, flat bolt holes, thick:
http://completeoffroad.com/i-123392-...ds707233x.html
Old June 10th, 2010, 01:36 PM
jaherring's Avatar
jaherring
Jason Herring
94 D90 ST #1253
Pardon the dumb question, but isn't the rear cover at least welded on, or do I have a different axle? Mine rusted through (originally a midwest truck..) in a small spot and I repaired it w/ JB Weld because I couldn't swap it out easily :-) I thought about welding on the sewer pipe cover repair at the time but then got distracted by other things... this was a couple years ago...
Old June 10th, 2010, 01:37 PM
Different axle.
cover
Hitch Mounted Cargo Carrier & Car Cover gamberik For Sale - Parts 5 January 5th, 2006 02:49 PM
Disco Axle, Tire Cover, D-90 top, D-90 rear seat, Safari Gard Bumper m016324 For Sale - Parts 17 January 4th, 2006 09:20 AM
Spare Tire Cover (Stiffback?) Wanted D90JMUR Wanted 3 September 29th, 2005 05:36 PM
Brand New XD Tire Cover kpracer For Sale - Parts 0 December 23rd, 2004 07:33 AM
broken valve cover bolt...help!!!!!!!!! erik d Defender Technical Discussions 2 November 10th, 2003 03:12 PM
