can I use any Dana 60 cover ? - Page 2 - Defender Source
Old June 10th, 2010, 02:34 PM
Rugbier's Avatar
Rugbier
Gustavo
I was going to use the ARB covers if I was going to put ARB lockers.
The people at ARB usa never asnwered my question as to have a compatible cover for front DI/RRC/D90-110
They claim the rear is Salibury will work
Only available in Red and comes with a dipstick to meassure the fluid
NO SIGNATURE
Old June 10th, 2010, 03:38 PM
If it is not clear.... They work with a Salisbury axle. The Salisbury axle is a Dana 60. It is used on the rear of 110s and 130s until around 2005? or so. The cover bolts are a different size to normal Dana 60s, though. Normal Dana 60s use 3/8" bolts. Salisburys use 10mm. You will need to get your own bolts.
Old June 17th, 2010, 06:49 PM
brn24whl's Avatar
brn24whl
Eric
1994 RRC SWB
I got my ARB diff cover today and in the instructions Land Rover is listed as an application. Now to get the correct bolts and get the locker installed. The cover might be expensive but wow is it heavy duty.
Eric
Eric Riston
1-800-533-2210 ext 231
Direct Line 518-539-2231
Old November 6th, 2012, 01:16 PM
brn24whl's Avatar
brn24whl
Eric
1994 RRC SWB
Well it took me two and a half years but I finall got mine installed. Looks great IMO
Eric Riston
Old November 6th, 2012, 01:43 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Looks good Eric!
Old November 6th, 2012, 01:48 PM
brn24whl's Avatar
brn24whl
Eric
1994 RRC SWB
Originally Posted by don View Post
Looks good Eric!
Eric Riston
Old November 6th, 2012, 02:37 PM
brn24whl's Avatar
brn24whl
Eric
1994 RRC SWB
Well kind of. The diff cover look nice but the rest of the under carriage could use some pressurewashing.
-Jeff
Mud added via photoshop for effect
Eric Riston
Old March 18th, 2016, 01:45 PM
xjahx's Avatar
xjahx
JAH
'93 NAS 110, '94 NAS ST, '85 90 PU
I know this is old, but why make a new thread when this already has great info?
M10 x 20mm bolts but what head did you use, socket cap screw or hex? 1.5 pitch, I assume. Looks like the ARB comes with 3/8 socket cap screws. 25ft/lbs is the rec torque that I found.
Old March 18th, 2016, 06:00 PM
xjahx's Avatar
xjahx
JAH
ARB Dana 60 cover to Salisbury Diff ($200):
4x m10x40mm cap screws
6x m10x20mm cap screws
Summit Racing and other generic / Ford F-350 covers ($30, steel, chromed or painted):
10x m10x20mm hex bolts
Gasket: used permatex 99070 the right stuff gasket maker, allowed it to dry on the diff cover prior to installing.
Total time: 1hr in two stages. I wire wheeled the diff and axle prior to breaking the seal on the differential, applied phosphoric acid, and then finished with a coat of por-15.
Old March 19th, 2016, 12:03 PM
samer0214's Avatar
samer0214
Samer Hijazi
1997 P38 Vitesse
Yes expensive, but ability to check fluid level via dipstick: Priceless!
Thank you - Samer
1997 P38 Vitesse (Red)
2003 Discovery II
Defenderless, for now!
Old March 19th, 2016, 12:28 PM
xjahx's Avatar
xjahx
JAH
Agreed, a nice feature. Luckily, my 110 came with a new ARB cover just waiting for installation. Once I figured out the bolts per above, the task was simple!
cover
Hitch Mounted Cargo Carrier & Car Cover gamberik For Sale - Parts 5 January 5th, 2006 02:49 PM
Disco Axle, Tire Cover, D-90 top, D-90 rear seat, Safari Gard Bumper m016324 For Sale - Parts 17 January 4th, 2006 09:20 AM
Spare Tire Cover (Stiffback?) Wanted D90JMUR Wanted 3 September 29th, 2005 05:36 PM
Brand New XD Tire Cover kpracer For Sale - Parts 0 December 23rd, 2004 07:33 AM
broken valve cover bolt...help!!!!!!!!! erik d Defender Technical Discussions 2 November 10th, 2003 03:12 PM
