Can I use a Dome light switch for hella lights - Defender Source
Old September 4th, 2009, 09:41 PM
tebby's Avatar
tebby
Justin Tebbenkamp
95 D-90 ST
I have a 95 ST..with a dome light switch. It doesn't appear the dome light switch controls anything. Is this switch orginial equip? Being it has three positions...I'm assuming its ON--OFF--ON........OFF being the middle position. Can I use the dome light switch to control a pair of lights with one of the ON settings, and all four lights in the other ON position? I'm planning on using two relays...thanks for any help!!!
Old September 4th, 2009, 09:49 PM
Hoosier's Avatar
Hoosier
Chris Hinkle
More than I need
On the soft top, the light switch is part of the light above the rearview mirror. One on is when the door is opened and the other on is just on. Is there another light switch you are alluding to?
Old September 4th, 2009, 09:50 PM
Maybe, post a picture of this, as I am not sure what switch you are describing... It should work, as long as you use relays and it is set up correctly, since the switch in the cab only turns the relay on.
Old September 4th, 2009, 09:58 PM
my 95 has a two position dimmer switch, dim and cant hardly see. I am using one for my rear work lamp, I think its for the 110 dome light? Mine is off/on/on, I am using the double lamp. Why not just get the switch for the right hand side of the steering cowl for your hellas?
Old September 5th, 2009, 11:12 AM
Hoosier's Avatar
Hoosier
Chris Hinkle
More than I need
You will be using a relay, so almost any switch will do. I like covered switches so that I know when they're on.
dome light, ht, lights, switch
Tail Light Boot Installation - Fixing Hosed Tail Lights JimC Misc. Chit-Chat 1 July 11th, 2017 04:14 PM
brake light switch snuffer Defender Technical Discussions 7 March 28th, 2006 07:02 AM
Main light switch jchan88 Defender Technical Discussions 3 November 13th, 2005 09:43 PM
Rear Dome Light Stays On thug1313 Defender Technical Discussions 5 November 1st, 2004 08:33 AM
