Can I replace Panhard with car on ground? - Defender Source
Old January 18th, 2009, 08:59 PM
johnpiero
John Brancato
none
Hi all!
From my previous post you may know that my misaligned front axle is probably due to a bent Panhard Rod. I took your advice and purchased an adjustablt panhard rod from Rovertym.
$185 later, I'd like to save some money and install it myself before I take it in for alignment.
Car I simpley remove and install the new panhard rod with the car on the ground (NO jackstands or lift)? I'm concerend that the body could shift over if i do...OUCH!!!!
Old January 18th, 2009, 09:08 PM
yes... I have done it before. I replaced my stock one with an adjustable one. I aligned the holes from the OEM one and put it on. Not too hard. With yours being misaligned, I would have a deadblow hammer available.
Old January 18th, 2009, 09:09 PM
huck1974's Avatar
huck1974
shane cates
94 d90
one side threads forward and one reverse. I couldn't do it on the ground. I wouldn't do it on the ground sam I am...eggs and ham and stuff. Lift the truck up dude.! good luck and a good upgrade!
And hay
And I love you too
Old January 18th, 2009, 09:38 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
Originally Posted by johnpiero
Hi all!
Your mount was bent, did you replace it? The box looked off too. It's one piece and I hope you replaced it as the adjustable panhard will not adjust shorter that far.
2009 King of the Hammers
BUCK Wild Racing
Driver: Me
Co-driver: Pat Quirk
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old January 18th, 2009, 09:47 PM
WhiteD90's Avatar
WhiteD90
Johnathan Tisdale
93 110, 90 RockRR buggy
Hi all!
yes, have a friend or two handy to help get it lined up if it shifts a bit. You can always use your winch if you have one too.
Old January 18th, 2009, 10:38 PM
flynn23
Scott Kozicki
97 NAS D90 SW
I've done it on the grass before. Like huck1974 said, one side threads towards the rear of the truck and the other towards the front. The one on the driver's side is the one that I had more trouble getting aligned. If you have a good hydralic jack under the driver's door, you can adjust it so the holes are spot on. An impact wrench later and you're golden. The hardest part is getting the rest of the suspension out of the way so that you can get tools on the nuts n bolts, but a little patience and some adjustment of the jack and you should be good to go.
ac
Adjustable Panhard Rod with Heim Joints RyanS Defender Technical Discussions 21 August 12th, 2005 08:33 PM
Child Car Seat Laws Rick Carlisle Defender Technical Discussions 14 June 23rd, 2004 06:58 PM
Help!!! broke zerk and bent panhard rod Milo Defender Technical Discussions 3 June 14th, 2004 01:43 PM
Replacing ground wire questions vesparover Defender Technical Discussions 1 October 27th, 2003 04:01 PM
Replace tranny hump insulation??? JRowe Defender Technical Discussions 8 October 16th, 2003 10:35 PM
