Can I Get Softer Shocks and Springs? - Defender Source
Old January 6th, 2006, 01:58 PM
EdF
Ed Freeman
2000 90 TD5
Red face Can I Get Softer Shocks and Springs?
My current model 90 TD5 has the standard suspension which is too hard for comfort. I rarely use the 90 offroad and when I do it's only on forest tracks. My wife dislikes the ride more than me but as we're both going on some long trips this year I'd like to improve the ride quality to something more comfortable. I also find the vehicle tends to 'skitter about' on bad road surfaces (like every other 90 I've owned) especially on slippery, uneven surfaces which can be unnerving at times. Because the suspension is so hard, the vehicle seems to be deflected by an uneven surface rather than the bumps being absorbed. That's what it feels like anyhow. I don't believe there's anything wrong, it's just the standard cheap, agricultural suspension. Does anyone know where I can get a softer set-up as after-market retailers in the UK only seem to sell HARDER springs and shocks. I tried Koni adjustable shockers on my last 90 but the softest setting seemed the same as stock. I don't mind if the suspension was lowered, either.. I'd get stuff from the States/Canada if necessary. Thanks!
Old January 6th, 2006, 03:27 PM
ne4x4's Avatar
ne4x4
Ian McCormack
1984 Landrover 90
have you checked your tyre pressures they may be too high. Failing that switch the shocks to some pro-comp es9000 (10 stage velocity sensing ones) or similar.
ever noticed that sort of problem with mine and Ive got Very heavy duty springs on the front but then again my 90 is carrying a lot of weight
Springs & Shocks Install Tips javelinadave Defender Technical Discussions 29 May 12th, 2007 10:11 PM
Shocks and Springs? boshea Defender Technical Discussions 1 August 20th, 2005 04:10 PM
Lokking for shocks and springs or spacers Vadim Wanted 1 July 7th, 2004 05:26 PM
Front shocks outside of coil springs? castlerock4x4 Defender Technical Discussions 19 May 12th, 2004 04:23 PM
Springs and Shocks loykd Misc. Chit-Chat 18 April 20th, 2004 11:41 PM
