can I cut my bushings? - Defender Source
Old September 3rd, 2007, 11:52 PM
rgrrvr's Avatar
rgrrvr
DJ Menasco is The Dude
1995 D90
I have recently gotten some Ironman Radius arm bushings that I am installing on QT Rad arms. Problem is the bush has a little flange at each end and I cant squeeze it through the opening (even tried mashing it through using the Jack-All. Now I know some bushes come in 2 halves and I was wondering if I could cut these in two and install from each side or should I get them pressed in. Anyone have any experience or thoughts?
Old September 4th, 2007, 12:55 AM
Stmpede's Avatar
Stmpede
Andrew Najarian
'93 NAS D110 #43
my urethane ones came in two pieces so there is probably no harm in cutting them in half
bushings
Slotted Radius Arm Bushings -- Opinions? LRNAD90 Defender Technical Discussions 7 June 19th, 2006 11:37 AM
DAP bushings jorge Defender Technical Discussions 5 April 18th, 2005 08:39 PM
Body bushings - poly or factor rubber?? jaherring Defender Technical Discussions 15 February 10th, 2005 06:42 PM
Rockware Trailing Arms w/ good bushings lwg For Sale - Parts 1 January 9th, 2005 04:06 PM
