Can a Salisbury use a standard D60 master rebuild kit? - Defender Source
Old July 23rd, 2017, 04:59 PM
Naplm00
Matthew
Minus the ring bolts and the pinion nut.
Same shims/bearings/crush sleeve?
Old July 23rd, 2017, 05:27 PM
Chris B
72 + D1 drivetrain =?
http://www.defendersource.com/forum/...#/topics/48527
Old July 23rd, 2017, 05:36 PM
phoenix37's Avatar
phoenix37
john
Just went through this on my S1 essentially was able to swap in a standard D60 R&P and rebuild kit etc but the only part that was different was the bronze stub axle bushings...and those were a bitch to locate.. finally found a pair of NOS ones in the UK and two weeks later..the boxes were so dusty and crusty i was compelled to take a picture.
My salisbury is probably earlier than yours so you might not have the same issue.
Old July 23rd, 2017, 05:46 PM
Naplm00
Matthew
Originally Posted by Rocky View Post
This dosent say anything?
------ Follow up post added July 23rd, 2017 05:48 PM ------
Great thanks, saves me a ton of time locating all the parts. I'm just rebuilding the center diff so the axles don't matter too much. I was afraid that the pinion setup for shimming/bearings were different.
My Sals is a 83 build
kit, master, rebuild
FOR SALE: Defender LT230T Master Rebuild Kit JohnBullsBollocks For Sale - Parts 4 May 22nd, 2017 04:28 PM
FS: New Genuine steering drop arm rebuild kit kiphartzell For Sale - Parts 3 June 25th, 2013 10:19 PM
Rear Wishbone Ball Joint Assembly, Tie Rod End & Drop Arm Ball Joint Rebuild Kit BMGmotors Defender Technical Discussions 18 June 27th, 2011 01:59 PM
LT230 Linkage rebuild kit? bharris Defender Technical Discussions 6 March 29th, 2010 06:59 PM
Brake Master Cylinder Rebuild HELP Heath Defender Technical Discussions 2 August 7th, 2006 05:11 PM
