Can a loose vacuum advance diaphram assembly cause stalling issues? - Defender Source
Old June 10th, 2010, 08:07 PM
Neil McCauley's Avatar
Neil McCauley
Neil McCauley
94 ST, 97 ST, 93 110
I started to get this weird periodic stall which would then be fine only a few minutes later. So during the routine inspection today I noticed the vacuum advance assembly (the part that has 2 screws that go into the body) was loose and there was significant play up and down. I'm about to go outside and tighten it up but could that cause power loss as well as the stalling? Any help is appreciated thanks.
Neil
Robert Deniro
Old June 11th, 2010, 12:01 AM
bjf's Avatar
bjf
barry f
94 ST #395
MAF. I think the vacuum advance can cause issues but most people drive with them having a split diaphram
Old June 11th, 2010, 08:27 AM
Check for holes/tears in the tube runnning from the MAF to the plenum as well.
Old June 11th, 2010, 09:25 AM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
Barry, there is a very clean 95 RRC on the sale section .
- Charles Eames
Old June 11th, 2010, 01:59 PM
PTSchram
P. T. Schram
Down to only six!
Random periodic stalling with a return to operating shortly thereafter is likely to be the ignition amplifier. When it quits, quick (like a bunny) jump out and check for presence/absence of spark. If spark absent, it's probably the amp. I have them in stock, AllMakes brand, one year warranty, $69.95, IIRC plus USPS shipping.
One of the very few times I had to have my Disco towed was due to the vacuum advance can unscrewing from the distributor body.
Wrench to wheel, wheel to wrench
Old June 14th, 2010, 03:51 PM
Neil McCauley
Neil McCauley
Hey PT are those brand new ignition amps? Do you have a phone number so I can credit card order? Thanks for the help everyone, I had a dirty stepper motor (not sure if that was contributing) and after I tightened that vacum advance on the distributor the stalling went away, weird.
Robert Deniro
ac, assembly, vacuum
stalling fuel issues devinchi Defender Technical Discussions 0 June 17th, 2008 10:04 PM
Vacuum Advance revtor Wanted 2 June 2nd, 2008 11:24 AM
Vacuum Advance Andrew Vick Defender Technical Discussions 11 April 27th, 2007 08:25 AM
Vacuum Advance CGunther Defender Technical Discussions 0 September 28th, 2006 12:52 PM
stalling bjenk Defender Technical Discussions 5 May 7th, 2005 12:56 AM
» Defender Registry
Red
KGH
Delta
LoneRunner
Add your Defender
