Can a blocked heater core cause overheating (300TDI)? - Defender Source
Old December 8th, 2010, 03:37 AM
jaherring's Avatar
jaherring
Jason Herring
94 D90 ST #1253
Just curious if this is a scenario which could happen... if that bypass can't flow freely could things get too hot?
Old December 8th, 2010, 07:51 AM
diesel_jim's Avatar
diesel_jim
Jamie Austin
don't think so. plenty of challenge trucks don't even have heaters,and they're worked HARD.
check your head and/or gasket. tdi's are renowned for warped heads. i used one of those "sniff" testers to check for hydrocarbons (exhaust gas) in the coolant but it came back AOK, but the head still needed a skim.
overheating stopped then.
Old December 8th, 2010, 09:43 AM
pendy's Avatar
pendy
jim pendleton
89'd90
My experience is that the cooling circuit at the back cylinder head, returning to the water pump, needs to be working. Or it can cause hot spots and overtempuratures. Leading to headgasket failure. Then worse. So a blocked heater core is not a good thing, in my opinion.
legend in my own mind
300tdi, heater, overheating, tdi
NAS D110 Heater Core Removal Jon_Winningham Defender Technical Discussions 6 January 8th, 2014 11:23 PM
Getting at the heater core Campbell Defender Technical Discussions 24 August 26th, 2013 01:47 AM
WTB/WTT: for 87 RR heater core headdamage Wanted 2 November 17th, 2005 06:14 PM
Heater core ?? & FYI D90user Defender Technical Discussions 4 October 14th, 2005 03:27 PM
Heater core Burke Wanted 1 December 9th, 2004 12:21 AM
