camshaft carrier + camshaft TOO TIGHT - Defender Source
Old August 12th, 2016, 02:10 PM
trapaga7
antonio
2007 Land Rover Defender 110 SW
hey all,
Land Rover Defender, 110, year: 2006
I redid my head, bought the head gasket, and all is good.
the problem comes when I torque the bolts
at 22, the engine rotates (camshaft as well)
at 48 lbs the engine rotates (camshaft as well)
after the 90 degrees, 180 degrees, the engine rotates, but NOT the camshaft.
what could be my problem?? .... anyone??
could the carrier be warped or.... loose, or should I install a small gasket ??
thanks for any help,
Antonio
Old August 12th, 2016, 02:13 PM
300TDI?
Did you use the right head gasket? Did you measure piston protrusion?
Is the timing belt installed and setup correctly? Is there enough valve lash?
Old August 12th, 2016, 02:20 PM
trapaga7
antonio
Hello Red90,
no sir, it is a TD5
I did get the right head gasket.
and like I say, if I REMOVE the chain sprocket (that bolts on to the camshaft), the engine DOES move, as soon as I bolt the sprocket on to the camshaft, NOTHING moves.
Old August 12th, 2016, 02:23 PM
I would ask on a UK based forum. There is not much TD5 experience here.
Old August 14th, 2016, 08:15 PM
trapaga7
antonio
thanks for your advice,
I did go onto an Australian forum, and have gotten plenty advice/help.
thanks again !
carrier, ht
Keeping the Steering Tight ]-[ @ n $ Defender Technical Discussions 8 August 24th, 2012 06:04 AM
new transmission- tight in reverse ditskovich Defender Technical Discussions 1 April 18th, 2012 07:18 AM
How tight is too tight for hoses? aosias Defender Technical Discussions 9 March 18th, 2012 07:11 PM
How 'tight' should Shock Heim Joints be? LRNAD90 Defender Technical Discussions 4 March 26th, 2008 02:54 PM
is it water tight jimmy salmon Misc. Chit-Chat 7 December 27th, 2007 06:22 PM
