Cam Suggestions - Defender Source
Old November 21st, 2006, 09:44 PM
punter
1966 Series IIA
Cam Suggestions
I've got a 3.5L V8 from my D110, that I'm rebuilding...
Engine is out, stripped down, and at the machine shop.
I'm going to start ordering my parts for the rebuild and I'd like to know if any of you, that own this same motor, have installed an aftermarket cam in yours. If so, what did you use and how were the results?
I've got to replace my Cam and Lifters/Tappets anyway, so I'd like to see if I can get a little more ouf of the engine while I'm at it. Any recommendations?
Cheers,
Punter
Old November 21st, 2006, 09:59 PM
JackW's Avatar
JackW
Jack Walter
1966 109 SW Diesel
A stock 3.9 cam will really help a 3.5 motor - signifigant difference. You'll want to look at RPI's website www.v8engines.com
This page: http://www.rpiv8.com/engine-6a.htm
Old November 22nd, 2006, 01:40 PM
Crower cam is the way to go. revor found some cool lifters too. I knwo buick will work but search on pirate4x4.com and it will come up.
Ron
Old November 22nd, 2006, 05:41 PM
JackW's Avatar
JackW
Jack Walter
1966 109 SW Diesel
I put a Crane cam for a Buick/Olds V-8 in my 3.5 L 1985 Range Rover years ago - wound up having to put some shims under the rocker shaft stands because the base circle for the GM cam was larger in diameter than the Rover cam and it preloaded the hydraulic lifters too much. Just something else you need to check when you're changing cams.
Who has done an aftermarket cam? Bowtracer Defender Technical Discussions 7 June 25th, 2009 10:17 PM
Looking for Front Seat Suggestions smenzel Defender Technical Discussions 39 February 26th, 2006 07:55 PM
Cam choice kellymoe Defender Technical Discussions 11 February 20th, 2006 01:04 PM
crower cam not fitting vesparover Defender Technical Discussions 11 July 18th, 2005 11:32 PM
DIY Cam replacement, who's done the job kellymoe Defender Technical Discussions 6 December 17th, 2004 12:37 AM
