Calipers and Rotors 1988 "90" - Defender Source
Old March 17th, 2017, 08:37 AM
highwayusmc's Avatar
highwayusmc
Jason
1988 D90
Does anyone have a go to site for calipers and rotors? Time to upgrade the rusted out UFO's on my 1988 90.
Thank you,
Jason
Old March 17th, 2017, 09:40 AM
If you are buying new caliper and rotors, then you you should change to the more common ones used on the 110s. They use larger pistons and pads, so stop better. You could also change to vented, if you want as the cost is pretty much the same.
Any Rover parts supplier of your choice will be able to supply them. I would suggest using OEM parts for the calipers and pads. Rotors don't seem to matter.
Calipers for vented rotors stancey Wanted 20 March 23rd, 2017 03:02 PM
Calipers and rotors. rayfi For Sale - Parts 2 January 28th, 2014 05:49 PM
Converting 110 calipers to 90 fishEH Defender Technical Discussions 17 September 13th, 2012 09:58 AM
Front calipers for vented rotors ini88 Wanted 7 March 31st, 2012 06:09 PM
Will Calipers and rotors from a 10 spline D90 work on a Disco Axle tomaco1 Defender Technical Discussions 13 December 14th, 2010 10:16 PM
