caliper rebuilders for 110 ? - Defender Source
Old January 31st, 2012, 11:20 PM
Chris Velardi's Avatar
Chris Velardi
Chris Velardi
1975 101FC
Anyone know who might rebuild 110 front brake calipers (with stainless steel pistons ?)
Chris "V"
Old January 31st, 2012, 11:26 PM
It is not hard to DIY.
I am sure any rebuilder would do it, but I have only seen exchange and I am not sure if they have 110 ones. With the price of the vented conversion at 400-500 (last I checked) it seems penny wise and pound foolish to rebuild non-vented but YMMV.
Old February 1st, 2012, 08:35 AM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
I think A1 Cardone will. I called them some years back about some calipers and IIRC the person I spoke with said if they didn't have what I needed available, I could send mine for rebuild. You'd probably have to send the SS pistons with the calipers.
But as said, it's not a difficult DIY.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old February 1st, 2012, 09:01 AM
Naplm00
Matthew
x3 If you can get the proper parts a rebuild will only take about 10min per caliper if they are not all dirty and seized up
Old February 1st, 2012, 11:16 AM
Chris Velardi
Chris Velardi
1975 101FC
I need them rebuilt because they are rusted and seized up
Chris "V"
Old February 1st, 2012, 11:48 AM
Chris Velardi
Chris Velardi
1975 101FC
Anyone in the US selling stainless steel piston rebuild kits for the early 110's ?
Chris "V"
Old February 1st, 2012, 12:36 PM
Jpayne's Avatar
Jpayne
Jeff Payne
'83 110 3 Door
I was just searching for the same thing a little while ago. This info was offered in response on another thread:
"If you have the original calipers on your 110, the seal kit (AEU2539) is available from RDS or Rovahfarm. The parts manual doesn't show a part number for the pistons, and looking around on the net, I can't find any listing for pistons for the early calipers either."
I still haven't been able to find a replacement piston kit. I wonder if a machine shop could turn some out for a reasonable price.
Old February 1st, 2012, 12:50 PM
Naplm00
Matthew
http://www.ebay.com/itm/DEFENDER-110...81408710077828
Old February 1st, 2012, 01:12 PM
tjfslaughter's Avatar
tjfslaughter
thomas
Burbon
http://www.zeus.uk.com/land-rover.php
I was told that these guys are the ones to buy from...
Old February 1st, 2012, 01:19 PM
Rod Hayward's Avatar
Rod Hayward
Rod Hayward
95 D90 Green #2288
I had trouble finding them a couple years ago when I was in need... I think I ended up finding them at D.A.P.
8-track, gun rack, spittoon, gimbal mounted beer buoy, blah, blah, blah, blah......
Old February 1st, 2012, 02:02 PM
I am telling you, just do the D90 vented disc and caliper swap and be done with it.
Old February 1st, 2012, 02:07 PM
Chris Velardi
Chris Velardi
1975 101FC
DAP does not have the caliper rebuild kits for the 110 and I would consider doing a 90 caliper if they made them with a stainless steel piston and not a chrome plated one that gets eaten apart here in VT with road salt brine and all the other chemicals they spray on the roads Rovers North has bolt in new Pro Line replacement for $125 / caliper, with the VT winters I'm sure they will get eaten apart just like the originals
Chris "V"
Old February 1st, 2012, 10:38 PM
newfD90's Avatar
newfD90
Chance
93 NAS 110
Yup, that's what I recently did. Easier and better.
Chance
Old February 2nd, 2012, 10:36 AM
Chris Velardi
Chris Velardi
1975 101FC
I might put a group bulk buy from the UK for Stainless steel piston rebuild kits if the price is right , all you would need to know is what size piston are in your calipers (they are either 46mm x 31mm or 41mm x34mm
Chris "V"
Old February 2nd, 2012, 11:52 AM
So buy the new ones and new SS pistons and swap them out and stop running unobtainium.
Old February 2nd, 2012, 04:26 PM
May be interested...you thinking fronts and rears?
Old February 2nd, 2012, 05:49 PM
Chris Velardi
Chris Velardi
1975 101FC
Open to fronts and rears . So 90's disks and calipers will bolt in place or the early 110 fronts (without modification)?
Chris "V"
Old February 2nd, 2012, 08:03 PM
Bolts may be different, but my understanding is yes. Others will know best.
Old February 2nd, 2012, 09:02 PM
Chris Velardi
Chris Velardi
1975 101FC
Bolts are no problem bold holes not lining up is a whole different story
Chris "V"
Old February 2nd, 2012, 09:47 PM
Someone will confirm, but the holes should all line up.
110, rebuild
Occasional drip from my rear caliper tomaco1 Defender Technical Discussions 16 July 31st, 2010 01:58 PM
front caliper brakeline jabber Defender Technical Discussions 5 May 3rd, 2009 11:31 AM
Caliper rebuilding, suggested or to be avoided? Hans Defender Technical Discussions 10 September 3rd, 2005 07:10 PM
Rear brake caliper leak cgalpin Defender Technical Discussions 11 July 8th, 2005 11:56 AM
Caliper (left DriverSide) RoverChic For Sale - Parts 5 January 14th, 2005 11:44 PM
