Caliper Question - Defender Source
Old January 31st, 2009, 04:20 PM
fleabus's Avatar
fleabus
Dan
None :(
Caliper Question
I was changing the front brake pads today and one of the wiper seal retainers popped out. It had been bent up a bit so I was unable to get it back in place.
Is replacement as simple as pressing a new one back over the wiper seal or is it a more involved process? Also, any worries driving it about with this retainer missing until I can get a replacement?
Thanks!
-Dan
Old February 2nd, 2009, 04:23 PM
Gren_T's Avatar
Gren_T
Gren Thomas
1985 90 300tdi auto
Hi Dan, replace the retainer ASAP as it protects the inner seal, any crap in there and the seal is toast.
you can use the piston to guide the retainer back in place just tap it into place gently
Regards
Gren
Old February 2nd, 2009, 04:28 PM
landrovered's Avatar
landrovered
S. Smith
72 Series III 109 Diesel
Just did my RRC yesterday. There is a gasket kit with rings available from LR. I found it easiest to place a flat piece of metal over the ring with the upper seal in the ring and then use a pair of channel locks to gently press the flat bar until the retaining ring snaps into place. Make sure the rings are not bent or you will never get them straight. Also having a few extra around if a good idea till you get the hang of it. Another tip is use compressed air to pop the pistons out of the caliper.
Old February 2nd, 2009, 04:43 PM
fleabus's Avatar
fleabus
Dan
None :(
Thanks for the replies... I guess the parts are sold as a kit:
http://www.roversnorth.com/store/p-2...-defender.aspx
They are on the way, but probably won't get to it until Friday... I hope nothing blows up in the meantime.
Should I be able to tap the retainer back in with the pad simply removed or do I need to pull the caliper?
-Dan
Old February 2nd, 2009, 06:08 PM
Bowtracer's Avatar
Bowtracer
Peter Sherman
NAS 110
I would pull the cal
I do it this way;
clean the cal [wire brush & pick]
pop out the cups
pull the seals
clean things up ie cups grooves
install the inner seal the right way
wipe the cup with some cal lube
put the outer seal & retainer on the cup [near the outside edge]
install cup
press in the wiper & retainer with pvc fitting I had laying around
inspect to make sure the seal is in correctly
also you will get deatailed instructions in the box
front caliper brakeline jabber Defender Technical Discussions 5 May 3rd, 2009 11:31 AM
Range Rover Front Brake Caliper Question TDI Guy Misc. Chit-Chat 10 May 24th, 2006 08:14 PM
Rear brake caliper leak cgalpin Defender Technical Discussions 11 July 8th, 2005 11:56 AM
U Joint question Milo Defender Technical Discussions 4 August 24th, 2004 03:45 PM
