Calculating Re-gears - Defender Source
Old August 14th, 2016, 10:31 AM
Nooner's Avatar
Nooner
Ryan Noonan
1994 D90 NAS #159
After much geekery and nerd-dom, and way too much time tweaking, I have come up with Numbers spreadsheet that you can use to plug in your original tire size, transfer case, transmission, and R/P ratios into, in order to compare multiple setups and how it will affect your highway and crawl speeds, and how much your speedometer will be off.
Nooner's Gear Ratio Calculator (Dropbox link)
Recommend saving it to your computer and then working on it.
The file format is only in Numbers for now (sorry PC users), and I am on vacation, so it will be a little while before I can tweak it for Excel use...the drop down menus may not work for now if you try and open it in excel.
Speaking of drop down: anything in a yellow field may be changed...if you change something that is not in a yellow field, well... good luck with that.
The reason I created this was because although the Ashcroft website has a very good calculator, I found I already needed to have a decent base of knowledge to start using it and I wanted to "dumb it down"... I also wanted to be able to compare multiple setups simulaneously...
As far as drop down menus go, I included what I consider the most popular transmission ratios based on TeriAnn's Expedition Land Rover site website. I included typical LT230 ratios; stock, some of Dave Ashcroft's optional High TC ratios and some of Bill Davis' GBR LowTC ratios. R/P ratios are a combination of stock, Ashcroft, and GBR. I included Roverdrive as an option as well as Ashcroft Underdrive. As far as tire sizes, there are many many many different options, so I included basic diameters.
If anyone would like to see an option they really have to have, let me know and I'll add it in when I get the chance.
Let me know if you have any questions! I'm sure they will be many.
... And the chance of this working the first time off the bat is probably 15%
Old August 18th, 2016, 06:55 PM
Nooner's Avatar
Nooner
Ryan Noonan
1994 D90 NAS #159
Example of what it would look like if you started out with a stock D90 with LT77S, LT230, and 32" tires and were looking at R380 vs GM 6L80e options with different GBR/Ashcroft gearing.
Yellow squares are the drop down options... speedo errors and all efficiency deltas are based on comparison with the far left column.
Changes to the Speedo cells, MPH cells, or RPM cells propagate across all columns so you have a direct comparison. Driveline and tire size selections only affect that particular configuration.
This is the updated file now:
Name:	Regear Example.jpg
Old August 23rd, 2016, 11:10 PM
Nooner's Avatar
Nooner
Ryan Noonan
1994 D90 NAS #159
aaaand an Excel version
GEAR RATIO CALCULATOR - EXCEL VERSION -- that's the dropbox link
I'm also attaching a zipped version of the file directly, since I finally figured out how to do that and I'm finally back home on my computer.
There you go... if anyone cares... I suppose most people who get this much into the weeds are going to want to make their own spreadsheet anyway.
I added places where you can input custom values for any of the fields instead of being stuck with the ones I though of.
I locked all the cells down except the ones you are supposed to change, but if you want to try your own hand at it, you can use the password (defendersource) and make it whatever you like.
Hope someone finds it useful.
Cheers
Ryan
Old August 24th, 2016, 12:48 AM
GuamPilot's Avatar
GuamPilot
Mike & Carrie Wendt
1986 90 2.5NA
THANK YOU!!! I appreciate all your work.
I'll download and give it a try when I get home in a few days.
Mike & Carrie
Defenders draw attention. Don't buy one if you're shy!
Old September 6th, 2016, 04:30 PM
koshow's Avatar
koshow
Kenji
95/D90
Hi Nooner, just sent you a PM!
Old September 6th, 2016, 05:40 PM
cdb
Clark Bowen
Nice job. Thanks.
Any way of using Google Sheets since I have a Mac?
2011 RR HSE -
2001 GMC 2500 4wd
Old September 6th, 2016, 05:52 PM
Nooner's Avatar
Nooner
Ryan Noonan
1994 D90 NAS #159
Originally Posted by cdb View Post
Nice job. Thanks.
CBD try this one..it's the Numbers version zipped. If you don't have Numbers on your computer you should still be able to use it if you log into iCloud.
I don't have a google sheets version yet, I hadn't thought about that. If this doesn't work for you, PM me and I'll gen up a Google sheets version for you and post it here.
Cheers
Old September 6th, 2016, 06:12 PM
cdb
Clark Bowen
Cheers
Thanks for the offer, but I'd just be playing with the spreadsheet and wasting your time.
Plus, it would be for a Series 2a trans/t-case and a Mercedes turbo diesel. Not really a D90 item.
I enjoy using spreadsheets for simple problems and multiple possibilities and I thought you did an exceptionally well thought out job on this.
2011 RR HSE -
2001 GMC 2500 4wd
Old September 6th, 2016, 06:17 PM
koshow's Avatar
koshow
Kenji
95/D90
Nooner I just sent you another PM. Can't tell if they are going though. haha
grnrvrs's Avatar
grnrvrs
Paul
88
Let's see the IIA project. At least one inquiring mind wants to know!
1970 SIIA 88, Sold
Old September 6th, 2016, 11:26 PM
cdb
Clark Bowen
It used to be your 88" Bugeye Paul
ID:	157115   Click image for larger version
2011 RR HSE -
2001 GMC 2500 4wd
Old September 6th, 2016, 11:27 PM
grnrvrs's Avatar
grnrvrs
Paul
88
Yep, and updates are always welcome.
Sent from my SM-G920V using Tapatalk
1970 SIIA 88, Sold
Old September 7th, 2016, 04:55 PM
Nooner's Avatar
Nooner
Ryan Noonan
1994 D90 NAS #159
Thanks Kenji for pointing out a bug in the excel version... custom values should work now, and the Ashcroft 4.37 ratio had an extra decimal that buggered everything up.
version 2.0 attached
how tough is it to replace 1.22 LT230 gears with 1.4 gears cdb Defender Technical Discussions 13 January 5th, 2015 05:28 PM
LT230 with 1.4 gears or just the 1.4 gears!! El Solis Wanted 3 May 13th, 2011 07:56 PM
Factory New Center section with gears and differnetial vlocci For Sale - Parts 1 January 2nd, 2004 03:13 AM
4.10 gears and Detroit locker dave_lucas For Sale - Parts 3 December 1st, 2003 03:03 PM
Setting up 4.10 gears TDI Guy Defender Technical Discussions 4 November 23rd, 2003 05:17 AM
