Bypassing 300 tdi lift pump - Defender Source
Old April 6th, 2014, 10:34 PM
vlocci
Vin Loccisano
After experiencing some fuel starvation indicators i installed an electric lift pump in my 300 tdi. It is before the mechanical lift pump which is still installed.
It solved my concerns but now i wonder if there is a reason to keep the mechanical pump inline.
Can i simply bypass the mechanical pump while keeping it physically installed? This would eliminate the need for a blockoff plate and remove any concerns of a diaphram failure
Vin
Old April 7th, 2014, 01:23 PM
hillstrubl's Avatar
hillstrubl
Danny
2005 Disco 3
I would think that leaving it in place (and plumbed) shouldn't do anything, the fuel would just go through it under pressure from your electric pump (before) and pulled from the injection pump (after).
Correct me if I'm wrong.
What electric pump did you use?
~2005 Disco 3 "Moneypenny"
~2008 GTI TSI
Old April 7th, 2014, 01:30 PM
You should make sure there is a non return valve in there somewhere or that the electric pump acts as one. The lift pump includes one. It helps prevent fuel back draining to the tank if there is a small air leak.
Old April 7th, 2014, 02:54 PM
Doesn't lowering the lever on the lift pump basically disable it?
Old April 9th, 2014, 08:58 AM
vlocci
Vin Loccisano
For those interested, I bypassed the mechanical lift pump without issue. No change in performance.
My reasoning for doing so was a failed diaphragm on a mechanical pump years ago that pumped diesel into the engine case. A real mess and it would have certainly done some serious damage had it not been caught.
Looking to avoid this mess and eliminate something that is not doing a thing I simply eliminated the mechanical pump.
I did leave it in place, rather than fabricating a small cover for the block.
I'm running a very generic facet style pump located near the tank. It maxes out at 7 psi or so and is the typical clicker pump. Makes priming the fuel filter a simple affair.
Vin
300 tdi, tdi
Bypassing oil cooler on serp belt trucks? evilfij Defender Technical Discussions 1 August 27th, 2013 09:58 AM
feed 200tdi lift pump from Facet fuel pump ? kjva Defender Technical Discussions 1 September 7th, 2011 01:55 AM
300 tdi water pump housing pendy For Sale - Parts 0 February 3rd, 2009 09:17 PM
Bypassing Engine Imobilization ECU dmarchand Defender Technical Discussions 0 October 3rd, 2007 08:42 AM
Wiring question - bypassing ECU for rear defogger dmarchand Defender Technical Discussions 8 September 30th, 2004 11:21 AM
