Buzzing noise (short) when turning off ignition? - Defender Source
Old May 1st, 2016, 09:17 PM
ckg
Chander G.
1993 D110
Hi,
On my 110 I recently noticed that when I turn off the ignition there's a short (less than 2 seconds) buzzing noise that seems to come from under the car somewhere. Anyone know what that might be? It's definitely coming from some kind of thing with an electric buzzer...
This is a NAS 110 with an auto transmission (P38 I think) if that helps. 3.9L V8
thanks
Old May 2nd, 2016, 04:22 AM
Originally Posted by ckg View Post
Hi, On my 110 I recently noticed that when I turn off the ignition there's a short (less than 2 seconds) buzzing noise that seems to come from under the car somewhere. Anyone know what that might be? It's definitely coming from some kind of thing with an electric buzzer... This is a NAS 110 with an auto transmission (P38 I think) if that helps. 3.9L V8 thanks
It's the Air idle control valve being opened ready to start the car. It's the black solenoid valve in the rear of the plenum if you are interested in seeking it out.
Old May 2nd, 2016, 09:58 AM
ckg
Chander G.
1993 D110
I get that when I turn on the ignition - the buzz is when I turn it off. almost like the buzz one would hear if the key were left in the ignition in an older model car (but it's not that..)
Old May 2nd, 2016, 10:25 AM
Some 14cux set the aicv on shut off
Head turning D90 stories. Cyborg Misc. Chit-Chat 279 August 8th, 2017 09:42 PM
Weird noise/shitter when turning left. bjf Defender Technical Discussions 17 January 26th, 2015 01:13 PM
Electrical gremlin: Headlights, Dash, Pulsing Interior Lights, Buzzing FortyTwo Defender Technical Discussions 6 September 20th, 2014 02:44 PM
Buzzing relay for ARB lockers nathanwind Defender Technical Discussions 45 August 5th, 2012 09:57 AM
Manually turning speedo artm Defender Technical Discussions 8 February 12th, 2005 01:29 PM
