Buying Opinion - Defender Source
Old August 17th, 2004, 12:47 AM
crequet
Charles Requet
1995 d-90 #2442
Buying Opinion
I found a Yellow d-90 with 103000 miles. The owner said that he had just replaced the transmission and the transfer case. It has almost no rust at all, even in the battery box, the only place I notice rust was under the driver's floormat. They want $19500 for it.
Is this a good/bad price?
Thanks in Advance
Chuck
Old August 17th, 2004, 07:31 AM
It sounds good to me. I paid 15k for my truck with 128k miles. If you take it to a rover dealer for an inspection, they will be ridiculously nitpicky about its faults but that can be used as an additional bargaining point. I would certainly try to get the price down to at least 17.5 if you want to screw the guy down, but if you want the truck, youre probably getting a fair deal at 19.
Old August 17th, 2004, 08:25 AM
I would say if you know for sure the transmission and T-case are new then check out the engine, check the oil and makes sure it is not black or that it does not smell like gas or coolant. Pull a couple plugs and make sure they don't look that bad. Test drive it, make sure it doesn't overheat. The T-case goes for $1400, and the transmission goes for $1700 without the cost of installation, that would more then bring the price down to 15k. So at 19k you’re getting a pretty good deal.
buying
Buying A 94 Defender 90 With 40,000 Kilometers retep56 Defender Technical Discussions 2 December 9th, 2005 08:12 PM
Advice on buying my first D90 mtbrooks Defender Technical Discussions 7 July 19th, 2005 07:48 PM
Help buying R. chili Defender Technical Discussions 0 June 17th, 2005 12:39 PM
Buying a 95' ! Please help with pricing rcmorgan540 Misc. Chit-Chat 8 May 19th, 2004 10:33 AM
yet another tire ? / opinion BFG januconn92 Defender Technical Discussions 18 April 8th, 2004 10:23 AM
