Buying Advice: Rain + Soft Top + Outdoors - Defender Source
Old June 5th, 2013, 02:35 PM
Dragon Breath's Avatar
Dragon Breath
Jay
Blank
I'm deep in the process of looking for the right D90 and want a softtop or removable hard top (no SW). The D90 will live outside (during evenings and weekends and garaged at work on weekdays) and we get rain a few months out of the year -- the rest of the time it's bone dry.
1. I would like to know whether I should expect that it's inevitable that a good softtop (e.g., Badger II) will still leak. I haven't seen but a few removable hardtops out there so figure I'm probably going to have little choice but to buy a softtop. Can I fix any leaks that it may come with -- or is it inevitable that you can't stop leaking on Defenders if you expose them to a full day of rain?
2. If I want to find someone who can do a thorough inspection of a truck, what is the appropriate place to post to ask for recommendations?
Old June 5th, 2013, 02:38 PM
If you replace your vent seals, have a badger gutter kit soft top, and generally have well alligned doors, leaks in a stationary vehicle will be minimal.
Old June 5th, 2013, 02:53 PM
Dragon Breath
Jay
Blank
I see that gutter kit is something that can be purchased after the soft top was purchased, but can I install the kit if the top wasn't originally installed with it? I looked at the website and am having a difficult time determining whether you have to buy the GK version of the Badger II for this to work or whether it would also work if the truck comes with a Badger II Fabric Door Seal version. ?
Also, any idea if the GK kit can be removed and reinstalled? -- it would look funny if I took the top off in the summer.
Old June 5th, 2013, 02:58 PM
Use the search button a little. Search gutter kit, gk, and the like. I have a GK on my truck (look at my registry for pics). It doesn't look dumb on my truck with the top removed, but some say that it takes away a little from the full open-top feel of a D90 ST. The GK "fins" tend to be in the perfect spot to block the blinding sun, so I actually like them on with the top off.
Yes, the Badger for GK must be used with a gutter kit, and a fabric door seals one was not built/intended for the gutter kit...hence why they are completely separate items for sale.
Old June 5th, 2013, 03:12 PM
Dragon Breath
Jay
Blank
I see what you mean -- it looks good on yours compared to the photo on the website. Yours is black/powdercoated so it doesn't look out of place.
Old June 5th, 2013, 03:16 PM
I am a fan of the FDS over the gutter but I don't care about water leaks.
Old June 5th, 2013, 04:59 PM
kinetic's Avatar
kinetic
Kinetic Adventures
TDI's
Even the station wagons leak... it's a rite of passage
Old June 11th, 2013, 09:30 AM
ssi19's Avatar
ssi19
scott
1995/D90
I went real high tech with a solution to my ST door drips. See below. just a flexible piece of plastic between door and top. Anytime it rains I throw it in each door. This cut out about 99% of the water dripping the inside of door and on the floor.
advice, buying, top
FS: 94 D90 soft top/cedar hard top $19,500 bigpalley For Sale - Vehicles 4 October 17th, 2005 06:57 PM
measurements on d90 soft top? def90 Defender Technical Discussions 0 August 31st, 2005 02:00 AM
Soft Top Alternatives ronward Defender Technical Discussions 7 May 7th, 2004 02:04 PM
Which is the best soft top for D-90? bbandit Defender Technical Discussions 13 March 9th, 2004 08:40 PM
soft top jperakis Wanted 25 December 7th, 2003 08:56 AM
