Buying a used Webasto (what to look for) - Defender Source
Old February 1st, 2016, 08:32 PM
Wilboro's Avatar
Wilboro
William Ficner
1997 110 csw
As my truck goes back together I've been thinking it would be pertinent to install a Webasto Thermo Top C, since I do live up in Canada.
I've been looking at used ones, but typically the descriptions are vague..."running when removed a few years ago" etc etc. Knowing almost nothing about these units are there things I should be looking for? Do things commonly go wrong with them? Do they have a fairly set lifespan? Are they fully rebuild able if you were to get one and it ends up needing work?
Any advice would be greatly appreciated.
Will
Old February 1st, 2016, 08:40 PM
They rarely go wrong, IME. They are very well designed. They are fully rebuildable.
Pretty easy to hook up and test. Just run water through it from a tap, supply a bit of diesel and 12V.
Old February 1st, 2016, 08:42 PM
Wilboro's Avatar
Wilboro
William Ficner
1997 110 csw
That's good to know. Most of the ones I'm finding are out your way and I'm in Ottawa so I'm not sure I'll be able to test them.
Old February 1st, 2016, 08:55 PM
make sure it's a Z or C. Those are diesel. If the letters are something else, stay away from it. There are some that were OEM spec for auto manufacturer, and the circuit board is designed to tie in to the canbus of the car ecu. Those are not what you want for a stand alone install. And there are petrol versions. again, Z or C. the main difference between Z and C, is the water circulation pump. I have a Z with the pump, but a C is meant to be an aux and parking heater. Meaning, it can run on it's own when the engine isn't running (requiring circulation pump), or it can run with the engine to provide supplemental heat (no pump). You can add the pump as an accessory if it doesn't have it.
if you get a used one, get the full rebuild kit, to put new gaskets and glow plug on it, and make sure you open it up to clean out any carbon buildup.
Also, if you buy as parts and not a kit, go with an original webasto harness, not aftermarket like I did. the aftermarkets are just as good, but it's nice to have the wires color coded correctly when referring to the manual circuit diagram.
once you have it all, the biggest technical challenge you'll face is how to get the cabin heater fan to work with it. easily solvable with this crowd. Also, how to tap the fuel is the other challenge. I tied into my prefilter/seperator. most recommend dropping your fuel tank and giving it a seperate tap. easy to do with the tank out. DIY.
Mark Kellgren
KM4BOR
Old February 1st, 2016, 09:01 PM
Wilboro's Avatar
Wilboro
William Ficner
1997 110 csw
Ok that's great info. I've been looking at C's but had been unclear the differences and was unsure if they were all diesel exclusive.
I assume TSL 17 is just the part number for a C?
Old February 1st, 2016, 09:04 PM
all the manuals are out there on pdf. for any used one you find, google the whole part number to make sure its not an oem canbus type (eg stay away from BMW).
Mark Kellgren
KM4BOR
Old February 1st, 2016, 09:06 PM
Wilboro's Avatar
Wilboro
William Ficner
1997 110 csw
I've already got the thermo too c manual, I'll do that though with the part numbers to make sure I get the right one.
So just to clarify all thermo top c's are good to go?
Old February 1st, 2016, 09:15 PM
pretty much but not all. also, there's the owner/operator and the service manual. you'll want both.
here's a couple threads to understand the issue better.
http://www.canalworld.net/forums/ind...howtopic=54308
http://forums.lr4x4.com/index.php?showtopic=92940
Mark Kellgren
KM4BOR
Old February 1st, 2016, 09:16 PM
Wilboro's Avatar
Wilboro
William Ficner
1997 110 csw
pretty much. also, there's the owner/operator and the service manual. you'll want both.
Perfect!
Old February 1st, 2016, 11:29 PM
Way of Life's Avatar
Way of Life
1988 Defender D110
Hi Wilboro I live here in the great white north also I have a Webasto Thermo I got it all under the passenger seat (Puma 2.4) and plumped in, love it works great, I run it off one battery (I have duals) so I can also have power to start her. You can download all the manuals on line, I will look for the links when I get home if you want or can’t find them. I bought mine from a shop in the EU called Main page - www.carheaters.eu - Best heaters on the internet! New and used! Best prices! He gave me a full no worries return, it was 100% like he said it was and I was happy best part is working on them is easy.
A guy on defender2net gives a full low down on an install in the front fender area.
I bought for about 600 Canadian came with a 7 day timer and all, set the day and time and up she starts. Warm for wife going to work early mornings, when I’m not home.
Land Rover Defenders. 65 years heritage, minimal appearance changes, still going strong all over the world. Not a fashion vehicle, but fashionable to own. Made for the needy, not the greedy.
Old February 2nd, 2016, 07:16 AM
Tommieboy
Thomas
2000 Defender 110 TD5
I also have one in my Td5 and it's plumbed directly into the tank. My unit sits in the engine bay on the fender side close to the coolant reservoir. Remember to put in the check valve at the coolant reservoir, mine was trapping some air until I did that.
Old February 2nd, 2016, 07:21 AM
can you show me the check valve you are talking about? I dont have one.
Mark Kellgren
KM4BOR
Old February 2nd, 2016, 08:18 AM
mgreenspan's Avatar
mgreenspan
Matthew Greenspan
Land Rovers
If you wouldn't mind showing exactly what you did. I'm looking at getting one of these buy want to ensure DIY will be easy enough and not take too much time.
You little rebel, I like you.
Old February 2nd, 2016, 08:37 AM
Tommieboy
Thomas
You can see the check valve between the 2 clamps.
Old February 2nd, 2016, 08:45 AM
Tommieboy
Thomas
Not sure if it's considered gauche to post a reply from another forum however this is the source I used since the guy is local to me and I was able to consult him directly. It gives a good documented account on the Webasto TTC install.
Webasto engine pre-heater install Defender 110 Td5 LHD
Old February 2nd, 2016, 08:52 AM
That is a strange way to route the heater.
Normally it is placed in the supply line to the interior heater.
Old February 2nd, 2016, 08:54 AM
I see why you have a check valve now. That's not going to be necessary for non-TD5 water bottles, since all hose connections come in from bottom, preventing air return. That said, the webasto is supposed to be installed inline between the block and the heater on the internal circulation circuit when the tstat is closed. Having it involved with the expansion tank puts it on the external circuit of the thermostat. That doesn't make sense to me. when you are trying to warm the block up and the tstat is closed, you're basically warming the radiator.
------ Follow up post added February 2nd, 2016 08:55 AM ------
Red wins the brevity award for today...
Mark Kellgren
KM4BOR
Old February 2nd, 2016, 04:48 PM
Tommieboy
Thomas
It's installed according to the manufacturer's instructions for the Td5...and works well.
Old February 2nd, 2016, 04:51 PM
Wilboro's Avatar
Wilboro
William Ficner
1997 110 csw
I'm looking at a rebuilt and fully tested thermo top c unit with all the ancillaries, with only a switch no timer for $500 US. Is that a bargain?
Old February 2nd, 2016, 05:07 PM
Tommieboy
Thomas
You've likely checked out what they're going for new, if it's in good condition it seems a good price. I paid $700 (CDN) NIB, shipped. You're looking at another $200+ or so for the SmarTemp Fx timer.
buying, webasto
Webasto ThermoTop C and Webasto Fuel Pump flananuts For Sale - Parts 4 October 7th, 2015 09:08 AM
Buying a used Defender 90 in the USA ymc226 Defender Technical Discussions 53 May 27th, 2014 07:56 AM
What to look at when buying a defender? Corb4494 Defender Technical Discussions 2 January 6th, 2014 01:32 PM
Advices on buying used D90 on eBay reaper99999 Defender Technical Discussions 12 February 3rd, 2005 07:28 AM
Buying a used D90 - Please help arbik Defender Technical Discussions 14 January 13th, 2005 04:28 PM
