Buying a 110 pickup, some questions - Page 2 - Defender Source
Old September 21st, 2010, 10:36 AM
Originally Posted by rijosho View Post
Here's a 130 with the spare in the bed for another look.
http://seattle.craigslist.org/see/cto/1957961494.html
130's/high caps use a different setup all together. Since there is no fender well the length of the side of the truck there is no need for a tire well. The tires mount @ the back of the bed instead of up front on 110's.
Old September 21st, 2010, 01:38 PM
Naplm00
Matthew
What type of hardware is required for a bonnet mount? Im guessing the hood need some reinforcing?
Old September 21st, 2010, 01:46 PM
tjfslaughter's Avatar
tjfslaughter
thomas
Burbon
http://www.roversnorth.com/store/p-9...net-mount.aspx
http://www.roversnorth.com/store/p-1...ilability.aspx
Call them.
Old September 21st, 2010, 01:54 PM
Naplm00
Matthew
nice thanks for the ultra fast response.
This is the stout rear bumper for a jeep I found, looks like it could be used with a defender bumper sams the jeep lower by welding some blocks on the the bumper as pivot and latch/standoffs.
http://i9.ebayimg.com/03/i/001/29/ag/b2b4_12.JPG
no image tags on this forum?
Old September 23rd, 2010, 08:10 PM
Retrofit's Avatar
Retrofit
Pat
1984 110 CrewCab 200Tdi
Here is what I made for myself.
Its by no means perfect but it suits my need perfectly. It was cheap to build, robust, and allows for the tire to swing with the twin ladders in place and without obstructing the license plate.
Enjoy !
Pat
ID:	31455   Click image for larger version
ID:	31457   Click image for larger version
Kirk Lazarus, Tropic Thunder
Old September 23rd, 2010, 10:01 PM
Jpayne's Avatar
Jpayne
Jeff Payne
'83 110 3 Door
Enjoy !
Pat
Just wondering...
Did you bolt a plate across the whole length of your rear that the tire carrier, trailer hitch and recovery points are welded to? If so I like that idea, it gives everything a lot of extra strength.
Old September 23rd, 2010, 10:13 PM
Retrofit's Avatar
Retrofit
Pat
Yes I did, it's a 1/4 " steel plate on witch I also welded a 2" bottom plate that goes towards the front of the truck with small corner tabs.
Pat
Old September 24th, 2010, 07:47 AM
I like the double anti-luce latches - might have to do the same for my trailer!
110, buying
110 Double Cab Pickup spoted in West Hollywood Mark M Misc. Chit-Chat 13 August 26th, 2005 12:38 AM
NAS 110 A/C questions rcork Defender Technical Discussions 13 July 19th, 2005 01:16 PM
Thinking about "Defendering" a MOD 109 pickup - some questions for any.... solihul Defender Technical Discussions 1 May 19th, 2005 01:12 PM
Rear Mud Flap Mounting questions - it's a 110 but I assume same applies for 90's solihul Defender Technical Discussions 2 March 8th, 2005 04:21 PM
