Buy a new U-joint or new HD GBR shafts - Defender Source
Old October 1st, 2011, 12:43 PM
tebby's Avatar
tebby
Justin Tebbenkamp
95 D-90 ST
I have a rear U-joint going bad..quick. I have a 2inch rovertym lift. Should I just replace the rear joint or bite the bullet and buy new shafts. Will I have a continous problem w the joints due to the lift. thanks
Old October 1st, 2011, 01:35 PM
Ujoints are wear items. 400 on a drive shaft or a 30 dollar u joint. I was able to address my issues with rear links from rover tracks
Old October 1st, 2011, 04:28 PM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
US made u-joint is about $15, Neapco/PDQ 1-005 from Advance Auto.
Or $30 for a precision 344.
If one is bad, I'd do them both.
Yes they are wear items, but they'll wear a lot longer if greased correctly, and also greased at least every oil change. 5,000 miles is the service interval for "normal" use.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old October 1st, 2011, 05:01 PM
carlosz's Avatar
carlosz
Carlos
with a 2 inch lift you should not have to modify the driveline angle to te point of needing a new d/shaft.
I would replace the ujoints and call it a day.
GBR HD rear axle shafts with drive flanges crown14 For Sale - Parts 1 February 9th, 2011 07:36 PM
GBR Rear HD Half Shafts 98 HOO For Sale - Parts 4 August 28th, 2009 03:40 PM
GBR HD rear half shafts jvelador For Sale - Parts 8 August 13th, 2009 04:31 PM
What kind of DC shafts and axles is GBR selling? cbass Defender Technical Discussions 12 July 19th, 2005 01:03 PM
New HD Drive shafts TDI Guy For Sale - Parts 0 March 1st, 2004 08:51 PM
