Bushings - OEM vs poly - Defender Source
Old May 12th, 2015, 09:43 AM
alecbeard
Alec Beard
1972 Series III
Anyone have experience with aftermarket poly bushings or brand new genuine rubber bushings? I've heard conflicting things
Some say OEM are better, and if poly were better, then Land Rover would be using them.
Some say poly are better. Easier to install, just as durable.
Also I don't have a huge press. Is there another way to get the OEM bushings in other than a big press?
Old May 12th, 2015, 09:47 AM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
No question, Poly is super easy to install. Poly can also fail much worse than rubber, leaving the vehicle unable to drive on the road. I'm a huge believer in genuine rubber.
Old May 12th, 2015, 09:51 AM
alecbeard
Alec Beard
1972 Series III
How hard are they to get in? Do you have a press?
Old May 12th, 2015, 10:13 AM
JohnC
Giampaulo Cinquegrana
95 DI SR Extreme Kit - 94 RRC LWB
Not all Polybushes are made the same.
I have a "special set" on my 95 DI for the past 8 years without any issues.
John C.
Old May 12th, 2015, 10:29 AM
Roverdoc's Avatar
Roverdoc
Dan Kemper
1997 D90 SW #278
Genuine.
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
Not super hard, but yeah we have a press at work that I use for bushings.
Old May 12th, 2015, 10:45 AM
bjf's Avatar
bjf
barry f
94 ST #395
What's the consensus on poly for control arm bushings on a lr3/lr4?
Old May 12th, 2015, 11:12 AM
lordhelemt's Avatar
lordhelemt
Paul
1995 D90 #2620 & NAS 110
Just replace with a new arm. Removing the old bushings are nearly impossible. Take way too much time to cut them out
RIP 1994 D90 #999 (engine fire 2002). We'll miss you.
Old May 12th, 2015, 11:13 AM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
Agreed
Old May 12th, 2015, 11:18 AM
bjf's Avatar
bjf
barry f
94 ST #395
I saw in lro mag they now sell complete arms with poly.
Old May 12th, 2015, 11:42 AM
I removed all my bushings using a punch and lump hammer ... you need a small sharp punch and drive it down between the bushing and the radius arm or whatever. The outer sleeve of the bush folds in and when the punch is all the way through it drops out ... no drilling, burning or press needed.
I used poly bushes which go in easily or at worst needed some encouragement from a vice.
I like to learn the shady tree techniques as I dream of roaming the world in my truck! ;-)
Old May 12th, 2015, 11:48 AM
CDNRover's Avatar
CDNRover
Jeff Labbé
110 Ex-Mod FFR 200tdi
Renewed with genuine rubber as they are supposed to be superior to poly. It's a bugger to get them out and hard to install. A couple of them went bad after a year.. Replaced them again with genuine rubber.. Next time I'll swap them for poly as it is less hassle to fit. If they don't last as long as genuine rubber at least they'll be easy to renew.
Old May 12th, 2015, 12:25 PM
sflash868's Avatar
sflash868
Stephan Laputka
1995 D-90 SW
I say it depends on how you use your truck. If it's got a stock suspension and generally is a road queen, 100% original bushings. Long travel suspension, lift, lots of off road use, I'd go Poly not because they are more durable but because they are easy to change. My truck chews through bushings with the long travel suspension so I view them as a wear item. Poly bushings failed a number of times but I can swap them out in a third the time without cursing or the use of presses, torches, etc. I've also had much better luck with the poly oranges. Had poly blues and bushings were failing all over the place. No experience with the reds.
Whatever your do.. stay away from those castor corrected radius arm bushings AB sells. Man those were the worst to install and they were so stiff my race car had more flex than the defender did.
Old May 12th, 2015, 01:25 PM
alecbeard
Alec Beard
1972 Series III
That's my attitude as well. I figure where there's a will, there's a way. It's just physics. It's got to come out somehow.
Old May 12th, 2015, 02:14 PM
taoseno's Avatar
taoseno
Todd Kendrick
1995 D90 #2206 Original Owner
I have the Poly's and really like them but I agree it depends on how you use your truck............
Todd
'95 D90 #2206
'66 109" P/U
Old May 16th, 2015, 06:13 AM
tdi-rick's Avatar
tdi-rick
Rick
'98 130CC
If you can get Super Pro urethane bushes in the US for the Defender/RRC/Disco I I'd go for them every time over OE rubber, the current genuine rubber ones are crap.
The Super pro bushes are generally a better design than standard, they allow more articulation and are a softish durometer, or at least the durometer of the elastomer is tailored to the bush location.
An example of better design is the rear trailing arm to chassis bush. The SP bush has an annular groove and tapered faces on both bushes to allow material displacement during articulation and the mounting plate is a heavier gauge than the OE bush.
I don't have a photo handy but google it, you should be able to find a pic somewhere.
Old May 16th, 2015, 10:40 AM
I've used polys and they seem to work fine. Still have the same polys in my truck that I've had since 2011.
Old May 16th, 2015, 01:59 PM
alecbeard
Alec Beard
1972 Series III
Which polys do you use and where do you get them? Do you buy a kit or get them individually?
Old May 16th, 2015, 02:32 PM
I personally use the orange PU bushings from a Flo Flex kit (they are mostly two-piece bushings). They served my truck just fine. In fact, I sold my bushings off with my original radius arms, and they looked great when I took them off the truck last year.
I replaced the original radius arms with new-to-me RTE cranked radius arms and I installed with the stock bushings. I recently found that the stock bushes are totally knackered and causing noises. I ordered individual PU bushings.
I've heard polybush is the best, but that is purely anecdotal. My cheap bushes seem to work just fine.
Old May 16th, 2015, 02:35 PM
alecbeard
Alec Beard
1972 Series III
I recently found that my radius arm bushings were knackered and causing noises. I ordered individual PU bushings.
Where do you find these?
bushings, oem
Poly bushings Jake1996d1 Wanted 17 December 14th, 2012 02:54 PM
poly bushings roverman2010 Wanted 0 November 12th, 2012 01:58 PM
Poly Bushings? Use or Not? Hammertime Defender Technical Discussions 19 August 6th, 2011 04:05 PM
Body bushings - poly or factor rubber?? jaherring Defender Technical Discussions 15 February 10th, 2005 06:42 PM
